I have the problem that the Web Configurator is often not accessible. The browser then says something about ERR_CONNECTION_REFUSED. Sometimes the home page is also displayed, but the status is disconnected. The remote control actually sits in the dock the whole time. So it shouldn’t be because it goes to sleep.
Anyone else have problems like this? What can I do about it? Restarting the remote control doesn’t help. The only thing that helps is to wait and try again later.
For me connection with web configurator is only stable when using a wired connection to my network. When use my laptop with WiFi…is disconnect after few minutes.
Hi guys, had the same problem (I think). In my case, switching from the domain name (remotetwo-d1234…local) to the IP of the remote resolved the connection issues.
Quick side fact that I noticed, the remote has to be awake when configuring over the web interface. I was constantly lifting up the remote so I can work on the configuration.
