Integration Ideas 2.0
Hi @M.a.S.e and everyone,
I’d like to propose an integration idea for HDanywhere HDBaseT Matrix devices for the UnfoldedCircle Remote 2/3.
Device / Vendor:
HDanywhere – HDBaseT Matrix Switches
Support page: https://support.hdanywhere.com/
Official API:
Yes — there is an official API documented by the manufacturer:
Existing Home Assistant integration:
There is an existing integration for Home Assistant : GitHub - DealingLace/HDAnywhereMHUB-HA: Integration for easily controlling HDAnywhere video matrices via Home Assistant
What the UC integration could include:
  • Control of input → output routing (switching sources to displays)
  • Feedback for active routes
  • Power / standby control if supported by API
  • Scene/preset control
  • Possibly local vs cloud access options (based on API support)
If at least 3–5 folks are interested and ready to test, I think this would be a strong candidate for a new integration.
Thank you for all your work on existing integrations — they make this platform extremely powerful.
looking for eversolo testers: The_Moog JohnM ?
Eversolo complete
bluesound integration is ready: Bluesound Integration
I have a Lyngdorf MP40 and would love an integration. The IP control manual is here Download Center - Lyngdorf Audio , albeit I believe the commands can differ between the MP-60.Th3 reason I know this I was trying to get it working using tge base integration available from @kennymc.c and managed to get as far as power on/off and volume up/down working, and was using copilot to help map the commands, but I couldn’t work out how to get the Lyngdorf to provide response echo feedback consistently, and then copilot messed up the yaml formatting and started using all the wrong commands, as it went off and downloaded the MP60 manual all by itself and over- wrote mine, and wasted half a day exasperated because telnet commands were working but the Remote3 wasn’t, until I realised what it had done.Tgis was over Xmas break, but I haven’t managed to find a day to get back to it.
Happy to test though if one is made available.
Lyngdorf already exist: GitHub - jsoutter/uc-intg-lyngdorf: Lyngdorf Integration for Unfolded Circle Remotes
Ah thanks, missed tgat replied before reading the entire thread, will take a look
Many thanks @jsoutter will give it a try
I think a “Find My R3” integration would be great. From what I understand there is a speaker in the R3, not sure if we have access to that internal speaker though or how loud it can be?
Would be great to have a HTTP call or other way to trigger to be able to play some sounds to the internal speaker, maybe also flashing screen and haptic vibration.
Basically the same idea how you can use a smart tag to ring your phone.
Another idea might be to add a “Find My R3” button to the already existing android companion app :slight_smile:
But it should still be able to be activated seperatly, would love to just yell out to my nest speakers “Where is my R3” and have HA trigger it also.
Hallo,
Ich versuche die Integration UC Weather zu installieren. Leider bekomme Ich beim Hochladen der Datei folgende Fehlermeldung : Ungültiges Archiv,fehlende Daten im Archiv oder enthaltene Metadaten können nicht gelesen werden.
Ich hatte mich an die Readme Datei gehalten. Wenn Ich die Datei runterlade ist die Endung .tar und nicht .tar.gz
Ich hoffe auf Hilfe da Ich diese Erweiterung sehr spannend finde .
Vielen Dank für die Mühe.
Sorry. English please.
Thank you for the quick response.
The problem has been resolved.The Safari browser was the issue.
The Integration works wonderfully and looks good
Thank you!
Thanks, it works. I just use basic stuff like play/pause, next and whats playing
