I want to change the Home Assistant integration to use my Production HA rather than my Test instance
I would like to change the HA instance, but can’t see how to change the HA server. I am show the URL of the websocket, but am not given the choice to change it. I tried deleting the integration and re-adding it, but it still remembers the old URL and doesn’t allow it to be changed.
Not the same issue, but I recently had this problem - Home Assistant stopped working and disappeared from Add Integrations? - I could not get HA to uninstall and reinstall on the remote so I ended up wiping out the remote and restoring a backup. At that point, I was able to add the HA integration back in and reconfigure it.
I hope you find a much easier, cleaner way to do this! But worst case maybe you can go the nuclear route.
This issue was previously covered here: Home assistant, how to change websockets ip adresse I’d forgotten that I’d needed to do the same thing before :confused:
