Perfect. That worked. Thank you!
You welcome
For a longer period, the multi media widget does not work anymore. So I checked, If there ist an Integration update available and I updated from 1.1.1 to 2.0.7. If I now look into the configuration there are only two “old” entities inside. So I removed them but If I try to add new ones pressing the plus button, there ist nothing to choose.
Can anybody help me on this?
Many thanks
I solved it by running the integration setup again. So no more help needed!
awesome,. glad it worked out. and yeah, (i missed your earlier message). there was a MASSSSIVE change from version 1.x to 2.x, it require a full re setup.
Yes, I realized, that there ist now a very comfortable output selector. Perfekt!
awesome, glad you like it.
