Use of IR-Code-Set from Globalcache
Hi, need again your support.
I received the IR-Code-Set from global cache.com via email.
how can I now use these information? I know that I have to put these into a csv-file. Which format do I have to use and how to proceed. As far aas I know I can somehow use excel and than save as csv.. but I never tried this and want to avoid mistakes.
And after having the civ-file, how can I use that to put it into the remote.
Thanks in advance
Uwe
Maybe this will help to get you started:
One you have the csv file, create a new (blank) IR entity in the web configurator and upload the csv file.
Where do you get codeditor at, as I cannot locate it…also this is what my header now looks like is this correct?
key, code1, code, code2, hexcode2
CodEditor is text editor for Mac OS. You can use any other one that you have available. The header looks OK to me.
Sometimes the data from GlobalCache contains two different IR codes per command. In case hexcode 1 does not work, replace hexcode2 in the header instead. As far as I can see only the data in the columns called key and code are imported.
Thanks, now how do i save it as CSV i for the life if me could not figure it out.
Just replace (overwrite) .txt with .csv
thanks, I shall give it a try and see.
I still having problems, configurator doesn’t accept my csv-file… I downloaded the codes, received:
function, code1, hexcode1, code2, hexcode2
“AUDIO”,“sendir,1:1,1,38000,1,69,340,170,22,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,21,22,63,22,63,22,63,22,21,21,64,21,1519,340,85,22,1519”,“0000 006D 0022 0002 0154 00AA 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 05EF 0154 0055 0016 05EF”,
“CHANNEL DOWN”,“sendir,1:1,1,38000,1,69,342,172,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,21,21,21,22,63,22,63,22,21,22,21,22,21,21,21,22,63,22,63,22,21,22,21,21,64,21,64,21,64,21,1528,342,85,21,3654”,“0000 006D 0022 0002 0156 00AC 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F8 0156 0055 0015 0E46”,
“CHANNEL UP”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,22,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,21,21,64,21,64,21,21,22,21,22,21,21,21,22,21,22,63,22,21,22,21,21,64,21,64,21,64,21,1528,342,85,21,3654”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F8 0156 0055 0015 0E46”,
“CURSOR DOWN”,“sendir,1:1,1,38000,1,69,342,171,22,21,21,22,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,21,22,63,22,21,22,21,21,21,22,21,22,21,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,1529,342,85,21,3654”,“0000 006D 0022 0002 0156 00AB 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F9 0156 0055 0015 0E46”,
“CURSOR ENTER”,“sendir,1:1,1,38000,1,69,341,171,22,21,22,21,21,22,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,21,21,21,22,63,22,63,22,21,22,21,21,21,22,21,22,63,22,63,22,21,22,21,21,64,21,64,21,64,21,64,21,1528,342,85,21,3652”,“0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F8 0156 0055 0015 0E44”,
“CURSOR LEFT”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,64,21,21,22,63,22,21,22,21,22,21,21,21,22,21,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,63,22,1529,342,85,21,3655”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F9 0156 0055 0015 0E47”,
“CURSOR RIGHT”,“sendir,1:1,1,38000,1,69,341,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,22,21,64,21,64,21,63,22,63,22,21,22,63,22,21,22,63,22,63,22,63,22,21,21,21,22,63,22,21,22,21,21,21,22,21,22,21,21,64,21,64,21,21,22,63,22,63,22,63,22,1527,342,85,22,3651”,“0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150016 0015 0040 0015 0040 0015 003F 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 05F7 0156 0055 0016 0E43”,
“CURSOR UP”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,22,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,21,21,64,21,64,21,21,22,21,22,21,21,21,22,21,22,63,22,21,22,21,21,64,21,64,21,64,21,64,21,1528,342,85,21,3653”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F8 0156 0055 0015 0E45”,
“DIGIT 0”,“sendir,1:1,1,38000,1,69,342,171,21,21,22,21,22,21,21,22,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,21,22,21,21,64,21,21,22,21,22,63,22,21,21,21,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,63,22,1528,342,85,21,3652”,“0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 05F8 0156 0055 0015 0E44”,
“DIGIT 1”,“sendir,1:1,1,38000,1,69,343,171,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,22,63,22,63,21,64,21,64,21,22,21,64,21,21,22,63,22,21,22,21,21,21,22,63,22,63,22,21,22,21,21,64,21,64,21,64,21,64,21,21,22,21,22,63,22,63,22,21,21,1530,342,85,21,3653”,“0000 006D 0022 0002 0157 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0015 0040 0015 0040 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 05FA 0156 0055 0015 0E45”,
“DIGIT 2”,“sendir,1:1,1,38000,1,69,342,171,21,22,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,21,22,63,22,63,22,21,21,64,21,21,22,21,22,21,22,63,22,21,21,21,22,63,22,21,22,63,22,1525,341,85,21,3645”,“0000 006D 0022 0002 0156 00AB 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 05F5 0155 0055 0015 0E3D”,
“DIGIT 3”,“sendir,1:1,1,38000,1,69,341,171,22,21,21,22,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,21,22,21,22,21,21,22,21,21,22,63,22,21,22,21,21,64,21,64,21,64,21,64,21,64,21,21,22,63,22,63,22,1527,342,85,21,3650”,“0000 006D 0022 0002 0155 00AB 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 05F7 0156 0055 0015 0E42”,
“DIGIT 4”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,21,22,63,22,21,21,21,22,21,22,63,22,21,21,64,21,64,21,21,22,1528,342,85,21,3653”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 05F8 0156 0055 0015 0E45”,
“DIGIT 5”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,22,21,64,21,64,21,64,21,63,22,21,22,63,22,21,22,63,22,63,22,63,22,21,21,21,22,63,22,21,22,63,22,21,21,21,22,21,22,63,22,63,22,21,21,64,21,21,22,63,22,1528,342,85,22,3652”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 0040 0015 0040 0015 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 05F8 0156 0055 0016 0E44”,
“DIGIT 6”,“sendir,1:1,1,38000,1,69,340,170,22,21,22,21,21,22,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,63,22,21,21,21,22,21,22,21,21,21,22,21,22,21,22,21,21,64,21,64,21,64,21,1522,340,85,21,3640”,“0000 006D 0022 0002 0154 00AA 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F2 0154 0055 0015 0E38”,
“DIGIT 7”,“sendir,1:1,1,38000,1,69,340,171,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,21,21,64,21,21,22,63,22,21,22,21,22,63,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,21,21,1520,340,85,22,3634”,“0000 006D 0022 0002 0154 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 05F0 0154 0055 0016 0E32”,
“DIGIT 8”,“sendir,1:1,1,38000,1,69,342,171,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,21,22,63,22,21,21,21,22,63,22,21,22,21,21,21,22,63,22,21,22,63,22,63,22,21,21,64,21,64,21,1524,341,85,22,3645”,“0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 05F4 0155 0055 0016 0E3D”,
“DIGIT 9”,“sendir,1:1,1,38000,1,69,342,171,21,21,22,21,22,21,21,22,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,21,22,21,22,63,22,21,21,21,22,21,22,21,22,63,22,63,21,64,21,1523,341,85,21,3641”,“0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 00160015 0016 0015 0016 003F 0016 003F 0015 0040 0015 05F3 0155 0055 0015 0E39”,
“EXIT”,“sendir,1:1,1,38000,1,69,342,171,22,21,21,22,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,21,22,21,22,63,22,21,21,22,21,21,22,21,22,21,21,64,21,64,21,21,22,63,22,63,22,63,22,63,22,63,22,1528,342,85,21,3654”,“0000 006D 0022 0002 0156 00AB 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0015 0E46”,
“F LIST”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,22,63,21,22,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,21,22,21,22,21,21,21,22,21,22,21,21,22,21,63,22,63,22,63,22,63,22,63,22,1528,343,85,22,1528”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0016 003F 0015 0016 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0016 0015 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F8 0157 0055 0016 05F8”,
“F1”,“sendir,1:1,1,38000,1,69,341,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,64,21,21,22,21,22,63,22,63,22,21,22,21,21,64,21,21,22,63,22,63,22,21,22,21,21,64,21,64,21,21,22,1527,342,85,21,1527”,“0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0015 0016 05F7 0156 0055 0015 05F7”,
“F2”,“sendir,1:1,1,38000,1,69,342,171,22,21,21,22,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,21,21,21,22,21,22,21,22,21,21,64,21,21,22,63,22,1528,343,85,21,1528”,“0000 006D 0022 0002 0156 00AB 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 05F8 0157 0055 0015 05F8”,
“F3”,“sendir,1:1,1,38000,1,69,343,171,22,21,21,21,22,21,22,21,21,64,21,22,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,1528,343,85,21,1528”,“0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0016 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 05F8 0157 0055 0015 05F8”,
“F4”,“sendir,1:1,1,38000,1,69,343,171,22,21,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,63,22,21,22,21,22,21,21,21,22,63,22,21,22,21,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,63,22,1527,341,85,22,1527”,“0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 05F7 0155 0055 0016 05F7”,
“FAVORITE”,“sendir,1:1,1,38000,1,69,340,170,22,21,21,21,22,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,21,22,21,22,63,22,21,21,64,21,21,22,21,22,63,22,63,22,63,22,21,21,64,21,22,21,64,21,64,21,21,22,1522,341,85,22,3639”,“0000 006D 0022 0002 0154 00AA 0016 0015 0015 0015 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 0040 0015 0015 0016 05F2 0155 0055 0016 0E37”,
“FORMAT SCROLL”,“sendir,1:1,1,38000,1,69,340,171,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,21,21,22,21,63,22,21,22,21,22,21,21,21,22,21,22,63,22,63,22,21,21,64,21,64,21,64,21,64,21,1519,340,85,22,1519”,“0000 006D 0022 0002 0154 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0016 0015 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 05EF 0154 0055 0016 05EF”,
“FORWARD”,“sendir,1:1,1,38000,1,69,341,171,22,21,22,21,21,22,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,21,22,63,22,21,22,21,21,21,22,63,22,21,22,21,22,63,22,21,21,64,21,64,21,64,21,1527,342,85,22,1527”,“0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F7 0156 0055 0016 05F7”,
“FUNCTION BLUE”,“sendir,1:1,1,38000,1,69,343,171,21,22,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,21,22,21,21,64,21,64,21,64,21,21,22,21,22,21,22,63,22,63,22,21,21,21,22,21,22,63,22,63,22,63,22,1528,342,85,22,1528”,“0000 006D 0022 0002 0157 00AB 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0016 05F8”,
“FUNCTION GREEN”,“sendir,1:1,1,38000,1,69,343,171,22,21,21,21,22,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,21,22,21,22,63,22,21,21,21,22,63,22,21,22,21,21,64,21,64,21,21,22,63,22,63,22,21,22,1528,343,85,21,1528”,“0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 05F8 0157 0055 0015 05F8”,
“FUNCTION RED”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,21,22,21,22,21,21,22,21,21,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,22,63,22,1528,343,85,21,1528”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 05F8 0157 0055 0015 05F8”,
“FUNCTION YELLOW”,“sendir,1:1,1,38000,1,69,342,171,22,21,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,22,21,64,21,63,22,63,22,21,22,21,22,21,21,64,21,21,22,21,22,21,21,21,22,63,22,63,22,63,22,21,22,63,22,63,22,1527,342,84,22,1527”,“0000 006D 0022 0002 0156 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 003F 0016 003F 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 05F7 0156 0054 0016 05F7”,
“G LIST”,“sendir,1:1,1,38000,1,69,343,171,21,22,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,21,22,63,22,21,21,64,21,21,22,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,1529,342,85,22,1529”,“0000 006D 0022 0002 0157 00AB 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 00150015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F9 0156 0055 0016 05F9”,
“GUIDE”,“sendir,1:1,1,38000,1,69,343,171,22,21,21,21,22,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,21,22,21,21,21,22,21,22,21,21,64,21,22,21,21,22,63,22,63,22,63,22,63,22,63,22,1528,342,85,21,3653”,“0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0016 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0015 0E45”,
“HISTORY”,“sendir,1:1,1,38000,1,69,343,171,21,21,22,21,22,21,21,22,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,63,22,21,22,21,21,21,22,63,22,21,22,21,21,21,22,21,22,63,22,63,22,63,22,21,22,63,22,63,21,64,21,1530,342,85,22,1530”,“0000 006D 0022 0002 0157 00AB 0015 0015 0016 0015 0016 0015 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0015 0040 0015 05FA 0156 0055 0016 05FA”,
“INFO”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,21,22,21,22,63,22,21,22,63,22,21,21,21,22,21,22,63,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,1528,342,85,21,3654”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0016003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0015 0E46”,
“MENU MAIN”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,22,21,64,21,63,22,63,22,63,22,21,22,63,22,21,22,63,22,21,21,64,21,21,22,21,22,63,22,21,21,21,22,21,22,63,22,21,21,64,21,64,21,21,22,63,22,63,22,63,22,1529,342,85,22,3654”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150016 0015 0040 0015 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 05F9 0156 0055 0016 0E46”,
“MUTE TOGGLE”,“sendir,1:1,1,38000,1,69,343,171,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,21,22,63,22,21,21,21,22,21,22,63,22,21,21,21,22,63,22,21,22,63,22,63,22,63,22,21,21,64,21,64,21,1530,342,85,22,1530”,“0000 006D 0022 0002 0157 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 05FA 0156 0055 0016 05FA”,
“OPTION”,“sendir,1:1,1,38000,1,69,341,171,22,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,21,21,21,22,21,22,63,22,63,22,21,22,21,21,21,22,63,22,63,22,63,22,21,22,21,21,64,21,64,21,64,21,1529,341,85,22,1529”,“0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F9 0155 0055 0016 05F9”,
“PAUSE”,“sendir,1:1,1,38000,1,69,342,171,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,22,63,22,63,22,63,22,63,21,22,21,64,21,21,22,63,22,21,22,21,21,21,22,63,22,21,22,21,21,21,22,21,22,63,22,63,22,63,22,21,21,64,21,64,21,64,21,64,21,1525,340,85,22,1525”,“0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F5 0154 0055 0016 05F5”,
“PLAY”,“sendir,1:1,1,38000,1,69,342,171,21,21,22,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,21,22,21,21,21,22,63,22,21,22,21,22,21,21,21,22,63,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,1523,340,85,22,1523”,“0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F3 0154 0055 0016 05F3”,
“POWER TOGGLE”,“sendir,1:1,1,38000,1,69,343,172,21,22,21,21,22,22,22,21,21,65,21,21,22,64,22,21,22,63,22,63,22,63,22,63,22,21,21,65,21,21,22,64,22,21,22,63,22,21,21,65,21,65,21,21,22,21,22,64,22,64,22,21,22,63,22,21,21,21,22,64,22,64,22,21,22,1531,342,86,22,1531”,“0000 006D 0022 0002 0157 00AC 0015 0016 0015 0015 0016 0016 0016 0015 0015 0041 0015 0015 0016 0040 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0041 0015 0015 0016 0040 0016 0015 0016 003F 0016 0015 0015 0041 0015 0041 0015 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 003F 0016 0015 0015 0015 0016 0040 0016 0040 0016 0015 0016 05FB 0156 0056 0016 05FB”,
“PREVIOUS CHANNEL”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,22,21,64,21,63,22,63,22,63,22,21,22,63,22,21,22,63,22,63,22,21,21,64,21,64,21,64,21,21,22,21,22,21,21,21,22,63,22,21,22,21,21,21,22,63,22,63,22,63,22,1528,342,85,22,3654”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 003F 0016 003F 0016 003F 0016 0015 0016003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0016 0E46”,
“RECORD”,“sendir,1:1,1,38000,1,69,343,171,22,21,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,64,21,21,22,63,22,21,22,63,22,21,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,1528,343,85,21,1528”,“0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 05F8 0157 0055 0015 05F8”,
“REPLAY”,“sendir,1:1,1,38000,1,69,342,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,22,21,63,22,63,22,63,22,63,22,21,22,63,22,21,22,63,22,21,21,21,22,21,22,63,22,21,21,21,22,63,22,21,22,63,22,63,22,63,22,21,21,64,21,64,21,21,22,63,22,1528,343,85,22,1528”,“0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0016 0015 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 05F8 0157 0055 0016 05F8”,
“REVERSE”,“sendir,1:1,1,38000,1,69,341,172,21,21,22,21,22,21,21,21,22,63,22,21,22,63,22,21,21,64,21,64,21,64,21,64,21,21,22,63,22,21,22,63,22,63,22,21,21,21,22,21,22,21,22,21,21,21,22,21,22,21,21,64,21,64,21,64,21,64,21,64,21,64,21,64,21,1527,341,85,22,1527”,“0000 006D 0022 0002 0155 00AC 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 00400015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F7 0155 0055 0016 05F7”,
“SKIP”,“sendir,1:1,1,38000,1,69,341,171,22,21,22,21,21,21,22,21,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,21,22,63,22,21,21,64,21,64,21,21,22,21,22,63,22,21,22,21,21,64,21,21,22,21,22,63,22,63,22,21,21,64,21,64,21,21,22,63,22,1527,342,85,21,1527”,“0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 00150015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 05F7 0156 0055 0015 05F7”,
“STOP”,“sendir,1:1,1,38000,1,69,342,171,22,21,21,21,22,21,22,21,21,64,21,21,22,63,22,21,22,63,22,63,22,63,22,63,22,21,21,64,21,21,22,63,22,63,22,63,22,63,22,63,22,21,22,21,21,22,21,21,22,21,22,21,21,21,22,21,22,63,22,63,22,63,22,63,22,1524,341,85,22,1524”,“0000 006D 0022 0002 0156 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 0015 0015 0016 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F4 0155 0055 0016 05F4”,
changed the headline from “function” to “key” and from “hexcode1” to “code” (tried it also with “hexcode2” to “code”, rename the file to .csv, but the configurator would accept the csv-files. Where is my mistake?
Uwe
Are these really the codes from the GlobalCache email? The Hexcode looks way to long and as per the headline the should be five segments for every command but I can only see three.
For which device are these codes?
Yes, these have been the Codes i received from globalcache.com. The Codes should be for the Gigablue HD and HD QuadSeries Satellite Receivers - Set #: 1998
This might help. Convert GlobalCache to Unfolded Circle Upload Format - Quickly Online
The hexcode looks very long to me. I suggest you test one of the codes first before a bulk import. Just pick one of the codes and copy the hexcode into the web configurator and test if it works.
E.g. for „channel down“ it would be
Same error message, codes seem to be wrong…
Strange. I just copied one of the codes into one of my existing IR entities and it was accepted. I cannot test the code as I do not own the device but creating a command with the GlobalCache code worked for me.
Your CSV file should look like this. I’ve just tested it and it uploads with no issues:
key,code
AUDIO,0000 006D 0022 0002 0154 00AA 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 05EF 0154 0055 0016 05EF
CHANNEL DOWN,0000 006D 0022 0002 0156 00AC 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F8 0156 0055 0015 0E46
CHANNEL UP,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F8 0156 0055 0015 0E46
CURSOR DOWN,0000 006D 0022 0002 0156 00AB 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F9 0156 0055 0015 0E46
CURSOR ENTER,0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F8 0156 0055 0015 0E44
CURSOR LEFT,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F9 0156 0055 0015 0E47
CURSOR RIGHT,0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 0040 0015 003F 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 05F7 0156 0055 0016 0E43
CURSOR UP,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F8 0156 0055 0015 0E45
DIGIT 0,0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 05F8 0156 0055 0015 0E44
DIGIT 1,0000 006D 0022 0002 0157 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0015 0040 0015 0040 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 05FA 0156 0055 0015 0E45
DIGIT 2,0000 006D 0022 0002 0156 00AB 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 05F5 0155 0055 0015 0E3D
DIGIT 3,0000 006D 0022 0002 0155 00AB 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 05F7 0156 0055 0015 0E42
DIGIT 4,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 05F8 0156 0055 0015 0E45
DIGIT 5,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 0040 0015 0040 0015 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 05F8 0156 0055 0016 0E44
DIGIT 6,0000 006D 0022 0002 0154 00AA 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F2 0154 0055 0015 0E38
DIGIT 7,0000 006D 0022 0002 0154 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 05F0 0154 0055 0016 0E32
DIGIT 8,0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 05F4 0155 0055 0016 0E3D
DIGIT 9,0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0016 003F 0016 003F 0015 0040 0015 05F3 0155 0055 0015 0E39
EXIT,0000 006D 0022 0002 0156 00AB 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0015 0E46
F LIST,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0016 003F 0015 0016 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0016 0015 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F8 0157 0055 0016 05F8
F1,0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0015 0016 05F7 0156 0055 0015 05F7
F2,0000 006D 0022 0002 0156 00AB 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 05F8 0157 0055 0015 05F8
F3,0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0016 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 05F8 0157 0055 0015 05F8
F4,0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 05F7 0155 0055 0016 05F7
FAVORITE,0000 006D 0022 0002 0154 00AA 0016 0015 0015 0015 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 0040 0015 0015 0016 05F2 0155 0055 0016 0E37
FORMAT SCROLL,0000 006D 0022 0002 0154 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0016 0015 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 05EF 0154 0055 0016 05EF
FORWARD,0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F7 0156 0055 0016 05F7
FUNCTION BLUE,0000 006D 0022 0002 0157 00AB 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0016 05F8
FUNCTION GREEN,0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 05F8 0157 0055 0015 05F8
FUNCTION RED,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0016 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 05F8 0157 0055 0015 05F8
FUNCTION YELLOW,0000 006D 0022 0002 0156 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 003F 0016 003F 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 05F7 0156 0054 0016 05F7
G LIST,0000 006D 0022 0002 0157 00AB 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F9 0156 0055 0016 05F9
GUIDE,0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0016 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0015 0E45
HISTORY,0000 006D 0022 0002 0157 00AB 0015 0015 0016 0015 0016 0015 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0015 0040 0015 05FA 0156 0055 0016 05FA
INFO,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0015 0E46
MENU MAIN,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 05F9 0156 0055 0016 0E46
MUTE TOGGLE,0000 006D 0022 0002 0157 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 05FA 0156 0055 0016 05FA
OPTION,0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 05F9 0155 0055 0016 05F9
PAUSE,0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0015 0016 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F5 0154 0055 0016 05F5
PLAY,0000 006D 0022 0002 0156 00AB 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F3 0154 0055 0016 05F3
POWER TOGGLE,0000 006D 0022 0002 0157 00AC 0015 0016 0015 0015 0016 0016 0016 0015 0015 0041 0015 0015 0016 0040 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0041 0015 0015 0016 0040 0016 0015 0016 003F 0016 0015 0015 0041 0015 0041 0015 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 003F 0016 0015 0015 0015 0016 0040 0016 0040 0016 0015 0016 05FB 0156 0056 0016 05FB
PREVIOUS CHANNEL,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0016 0015 0040 0015 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 0015 0015 0015 0016 003F 0016 003F 0016 003F 0016 05F8 0156 0055 0016 0E46
RECORD,0000 006D 0022 0002 0157 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 05F8 0157 0055 0015 05F8
REPLAY,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0016 0015 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 05F8 0157 0055 0016 05F8
REVERSE,0000 006D 0022 0002 0155 00AC 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F7 0155 0055 0016 05F7
SKIP,0000 006D 0022 0002 0155 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 0015 0016 003F 0016 0015 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 0015 0015 0040 0015 0040 0015 0015 0016 003F 0016 05F7 0156 0055 0015 05F7
STOP,0000 006D 0022 0002 0156 00AB 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 0015 0015 0016 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F4 0155 0055 0016 05F4
TELETEXT,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 05F9 0157 0055 0015 05F9
TV/RADIO,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0016 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 05F9 0157 0055 0016 05F9
VIDEO,0000 006D 0022 0002 0156 00AB 0016 0015 0016 0015 0015 0015 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 0015 0016 0015 0015 0040 0015 0016 0015 0015 0016 0015 0016 0015 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 05F8 0157 0055 0015 05F8
VOLUME DOWN,0000 006D 0022 0002 0156 00AC 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0015 0016 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 05F9 0156 0055 0016 05F9
VOLUME UP,0000 006D 0022 0002 0157 00AB 0015 0015 0016 0015 0016 0015 0015 0015 0016 003F 0016 0015 0016 003F 0016 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0016 0015 003F 0016 0015 0016 003F 0016 003F 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0015 0015 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 003F 0016 0015 0015 0040 0015 05F8 0156 0055 0016 05F8
Thanks. Looks different from my Version (no „ „ etc. and much shorter). With these csv-Codes it worked without Problems. What has been my mistake? But thanks again!
When you imported the text file into a spreadsheet using commas as the separator the columns in spreadsheet should be: function, code1, hexcode1, code2, hexcode2
You needed to keep the “function” and “hexcode1” columns renaming them to “key” and “code” respectively. You needed to remove the “code1” column. In my file I also removed the “code2” and “hexcode2” columns just to be tidy
Hm, strange. I requested the code set for the Gigablue Sat receiver from Global Cache, copied the content of the email into CotEdior, replaced the column headers (function → key, hexcode1 → code), saved the file as csv and then imported the file into the web configurator without any problem (just uploaded the file without specifying a delimiter).
Anyway, you have it sorted it out in the meantime.
WHy bother with IR? Did you try the not so old Dreambox integration:
Do not take Dreambox serious it supports Enigma2 like my VUs and Octagon. If Gigablue did not change their OS it should work there too.
On this Integration the „Guide“ Button is missing… but i found a workaround… my question on using the IR was to learn how to use imported code-lists
