SkyQ Integration
MASSIVE UPDATE TODAY:
Introduction of 2 major features:
  1. add channel_select:XYZ command in sequence and activities. You can now set a custom command to set a specific channel, no more need for Macros.
  2. Add of Media_Player entitiy with Currently Playing media and show name.
A few notes:
  1. MASSIVE MASSIVE MASSIVE thank you to @harvey28 for working with me crazy close for the past few weeks, testing countless of attempts and spending significant amount of time providing fantastic debug information as i cannot test non of the features/fixes i do for this integration. Without him, this would not be possible.
  2. There is still one more bug to solve, the time it takes for the media widget to clear information and present new one. This bug is still in the works but again, due to the fact i do not have the device and its all done blindly, it take time to solve.
That being said, the new version is up and released.
I loaded 1.0.39 but can’t see the channel_select command in activities? Any ideas what I may be doing wrong please?
you set it up as command, you enter “channel_select:XYZ”. @harvey28 can you please explain the steps? i cant do it myself lol
Thanks. Had guessed that but it didn’t work. Rebooted remote and all working now. Appreciate you and M.a.S.e working on this. Much better solution than IR.
Out of interest how are you sending your PIN? I was using a macro for that. Is their a slicker way of doing that now with this IP based integration?
I was using a macro. I’ve reconfigured to try it with the send command, but I haven’t tested it yet. It should work.
So Send Command with just the digits as the payload?
yes, but as I said not tried it yet
new version with proper cache cleaning and image re-fetch + reboot survival. Release v1.0.41 · mase1981/uc-intg-skyq · GitHub
once again thank you to the awesome @harvey28_ could not have done it without you.
I’ve tried it and it works.
Hi M.A.S.E and Harvey28
I am having issues with the media player not displaying on the remote 3 widget.
I downloaded the 1.0.41 version and my media player widget worked well for a day or two. It then stopped displaying artwork, the media title and the channel details. I reverted back to the HA SKYQ integration that I have running and this displayed the artwork and channel as per usual. The HA integration does not display the title information which is my only gripe. As well as being an extra failure point.
I have updated to the latest 1.1.0 version in the hope this issue was resolved and my integration was not corrupted in some way. The logs show no errors and the data is correctly downloaded. I can see the channel, title and image url are all there. The image is just not displaying on the remote.
I have again reverted back to the HA SkyQ integration as a fall back so it’s not the end of the world but it would be nice not to rely on it. Any thoughts as to the issue?
Have you tired reboot the skyq box? Also, don’t assume the logs show nothing. Without logs, no way to help :wink:
On my way back home.
I can have a look in a couple of days.
I’ve rebooted the box to no effect. The Home Assistant SkyQ integration works so I’ll use this for now.
Here are the logs in case they are of use.
2025-10-28 14:54:29.482760 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,481 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: High Road, Low Road', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 14:54:29.479682 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,478 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 14:54:29.478078 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,477 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: High Road, Low Road', Image=True
2025-10-28 14:54:29.477394 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,476 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 14:54:29.476304 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,475 INFO [uc_intg_skyq.media_player]   title: High Road, Low Road
2025-10-28 14:54:29.476304 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,474 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 14:54:29.474659 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,473 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='21327dcc-384a-4fc6-83a1-836e2717ff8d', starttime=datetime.datetime(2025, 10, 28, 14, 30, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 15, 0, tzinfo=datetime.timezone.utc), title='High Road, Low Road', synopsis='Comedian Pat Shortt and his daughter Faye head off to Dubrovnik. While one of them stays in a luxury five-star hotel the other gets a bed in a local hostel. (HD)', season=2, episode=1, image_url='https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-498')
2025-10-28 14:54:29.470427 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,469 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 14:54:29.469409 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,468 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 14:54:29.468666 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,467 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 14:54:29.411367 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,410 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 14:54:29.410415 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,409 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 14:54:29.409399 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,408 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 14:54:29.142411 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,141 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 14:54:29.141599 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,140 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 14:54:29.140676 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,139 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 14:54:29.019354 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:29,018 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 14:54:19.016813 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,015 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: High Road, Low Road', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 14:54:19.013740 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,012 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 14:54:19.012150 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,011 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: High Road, Low Road', Image=True
2025-10-28 14:54:19.011662 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,010 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 14:54:19.010743 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,009 INFO [uc_intg_skyq.media_player]   title: High Road, Low Road
2025-10-28 14:54:19.010743 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,008 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 14:54:19.008665 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,007 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='21327dcc-384a-4fc6-83a1-836e2717ff8d', starttime=datetime.datetime(2025, 10, 28, 14, 30, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 15, 0, tzinfo=datetime.timezone.utc), title='High Road, Low Road', synopsis='Comedian Pat Shortt and his daughter Faye head off to Dubrovnik. While one of them stays in a luxury five-star hotel the other gets a bed in a local hostel. (HD)', season=2, episode=1, image_url='https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-498')
2025-10-28 14:54:19.004420 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,003 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 14:54:19.003618 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,002 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 14:54:19.002660 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:19,001 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 14:54:18.669674 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:18,666 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 14:54:18.669674 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:18,665 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 14:54:18.665365 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:18,664 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 14:54:17.480423 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:17,479 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 14:54:17.479624 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:17,478 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 14:54:17.478712 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:17,477 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 14:54:17.023775 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:17,022 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 14:54:07.021723 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,020 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: High Road, Low Road', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 14:54:07.018600 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,017 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 14:54:07.017099 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,016 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: High Road, Low Road', Image=True
2025-10-28 14:54:07.016654 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,015 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 14:54:07.015736 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,014 INFO [uc_intg_skyq.media_player]   title: High Road, Low Road
2025-10-28 14:54:07.015736 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,013 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 14:54:07.013694 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,012 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='21327dcc-384a-4fc6-83a1-836e2717ff8d', starttime=datetime.datetime(2025, 10, 28, 14, 30, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 15, 0, tzinfo=datetime.timezone.utc), title='High Road, Low Road', synopsis='Comedian Pat Shortt and his daughter Faye head off to Dubrovnik. While one of them stays in a luxury five-star hotel the other gets a bed in a local hostel. (HD)', season=2, episode=1, image_url='https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-498')
2025-10-28 14:54:07.009542 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,008 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 14:54:07.008678 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,007 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 14:54:07.007761 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:07,006 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 14:54:06.889070 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:06,888 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 14:54:06.888214 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:06,887 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 14:54:06.887106 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:06,885 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 14:54:06.576649 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:06,575 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 14:54:06.575979 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:06,575 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 14:54:06.575129 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:06,573 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 14:54:06.271934 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:54:06,270 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 14:53:56.271362 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,269 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: High Road, Low Road', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 14:53:56.268203 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,267 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 14:53:56.266802 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,266 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: High Road, Low Road', Image=True
2025-10-28 14:53:56.266252 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,265 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 14:53:56.265094 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,264 INFO [uc_intg_skyq.media_player]   title: High Road, Low Road
2025-10-28 14:53:56.265094 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,263 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 14:53:56.263198 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,262 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='21327dcc-384a-4fc6-83a1-836e2717ff8d', starttime=datetime.datetime(2025, 10, 28, 14, 30, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 15, 0, tzinfo=datetime.timezone.utc), title='High Road, Low Road', synopsis='Comedian Pat Shortt and his daughter Faye head off to Dubrovnik. While one of them stays in a luxury five-star hotel the other gets a bed in a local hostel. (HD)', season=2, episode=1, image_url='https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-498')
2025-10-28 14:53:56.258823 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,258 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 14:53:56.257933 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,257 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 14:53:56.256977 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,256 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 14:53:56.144714 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,144 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 14:53:56.143791 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,143 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 14:53:56.142950 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:56,142 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 14:53:55.848224 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:55,847 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 14:53:55.847279 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:55,846 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 14:53:55.846562 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:55,845 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 14:53:55.664436 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:55,663 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 14:53:45.662957 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,661 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: High Road, Low Road', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 14:53:45.659761 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,658 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 14:53:45.658193 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,657 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: High Road, Low Road', Image=True
2025-10-28 14:53:45.657549 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,656 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 14:53:45.656339 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,655 INFO [uc_intg_skyq.media_player]   title: High Road, Low Road
2025-10-28 14:53:45.656339 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,654 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 14:53:45.654393 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,653 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='21327dcc-384a-4fc6-83a1-836e2717ff8d', starttime=datetime.datetime(2025, 10, 28, 14, 30, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 15, 0, tzinfo=datetime.timezone.utc), title='High Road, Low Road', synopsis='Comedian Pat Shortt and his daughter Faye head off to Dubrovnik. While one of them stays in a luxury five-star hotel the other gets a bed in a local hostel. (HD)', season=2, episode=1, image_url='https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-498')
2025-10-28 14:53:45.650112 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,649 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 14:53:45.649301 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,648 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 14:53:45.648591 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,647 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 14:53:45.534144 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,533 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 14:53:45.533233 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,532 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 14:53:45.532206 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,531 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 14:53:45.348736 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,347 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 14:53:45.347827 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,347 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 14:53:45.346851 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,345 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 14:53:45.164373 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:45,163 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 14:53:35.163859 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,162 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: High Road, Low Road', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 14:53:35.160679 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,159 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 14:53:35.159087 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,158 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: High Road, Low Road', Image=True
2025-10-28 14:53:35.158180 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,157 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 14:53:35.157083 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,156 INFO [uc_intg_skyq.media_player]   title: High Road, Low Road
2025-10-28 14:53:35.157083 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,155 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 14:53:35.155442 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,154 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='21327dcc-384a-4fc6-83a1-836e2717ff8d', starttime=datetime.datetime(2025, 10, 28, 14, 30, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 15, 0, tzinfo=datetime.timezone.utc), title='High Road, Low Road', synopsis='Comedian Pat Shortt and his daughter Faye head off to Dubrovnik. While one of them stays in a luxury five-star hotel the other gets a bed in a local hostel. (HD)', season=2, episode=1, image_url='https://imageservice.sky.com/pd-image/21327dcc-384a-4fc6-83a1-836e2717ff8d/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-498')
2025-10-28 14:53:35.153355 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,150 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 14:53:35.153355 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,149 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 14:53:35.149361 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:35,148 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 14:53:34.058907 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:34,055 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 14:53:34.058907 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:34,054 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 14:53:34.054550 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:34,053 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 14:53:32.526210 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:32,525 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 14:53:32.525149 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:32,524 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 14:53:32.524289 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:32,523 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 14:53:31.808589 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 14:53:31,807 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING
Thank you, a couple of questions if thats ok.
Does this work for a day or two and just randomly stop? have you tried rebooting the skyQ or remote to re-establish the integraiton? if you change a channel, nothing is displayed on the screen? not channel info etc? is it something which can be replcated or just stop working after a while? i myself cannot replicate as i wrote this integration blindly, i do not own a SkyQ device so i cant replicate, the log , is it possible to share full log and not cut snippet? . if you prefer to use the HA integration and it works better for your usecase, sound good.
Hi M.a.S.e
Sorry I had to cut the log as it was too long to upload. The data was just a repeating pattern of what I uploaded above. It was just polling for any changes and none were made. I’ve added additional logging below that might prove more useful. Again it had to be cropped so I’ll upload it in sections. Sorry about this.
The media widget does not work at all. It worked very briefly when I first created the SkyQ remote media player but only after several reboots of the remote and exiting and entering the activity from the Home Screen. After a day or two it stopped working and nothing has resolved it. No media playing information appears on the Remote3 now at all even after the most recent version bump for the SkyQ integration.
All the other functions of the integration work flawlessly once mapped to remote buttons or on-screen buttons.
Anyway it’s not a problem as my Home Assistance integration works just as well with the same latency. The only issue is that it doesn’t display the title of the now playing channel as yours does unless that is the issue. That’s a small gripe. I’ll continue with it so don’t worry too much about it.
2025-10-28 17:54:59.602103 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,601 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 1270 ===
2025-10-28 17:54:59.601572 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,601 INFO [uc_intg_skyq.media_player]   live: True, sid: 1270
2025-10-28 17:54:59.601239 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,600 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ2 HD', channelno='102', image_url='https://imageservice.sky.com/logo/skychb_1270rté2hd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=1270, pvrid=None, live=True)
2025-10-28 17:54:59.580447 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,579 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 17:54:59.579934 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,579 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 17:54:59.579456 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,578 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 17:54:59.556383 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,555 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 17:54:59.555736 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,554 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 17:54:59.554900 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,554 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 17:54:59.473665 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:59,473 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:54:49.970898 +00:00	ui	INFO	uc.ui.input: Key released: "CHANNEL_UP" "Activity_QMLTYPE_242(0x55aaf2b600)"
2025-10-28 17:54:49.844401 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,843 DEBUG [ucapi.api] [('127.0.0.1', 41660)] ->: {'kind': 'resp', 'req_id': 24, 'code': 200, 'msg': 'result', 'msg_data': {}}
2025-10-28 17:54:49.843694 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,843 INFO [uc_intg_skyq.remote] Command 'channelup' sent successfully to SkyQ Device (192.168.0.150)
2025-10-28 17:54:49.786551 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,784 DEBUG [ucapi.api] [('127.0.0.1', 41660)] <-: {"kind":"req","id":24,"msg":"entity_command","msg_data":{"cmd_id":"send_cmd","entity_id":"skyq_remote_skyq_192_168_0_150_9006","entity_type":"remote","params":{"command":"channelup"}}}
2025-10-28 17:54:49.785317 +00:00	ui	INFO	uc.ui.input: Key pressed: "CHANNEL_UP" "Activity_QMLTYPE_242(0x55aaf2b600)"
2025-10-28 17:54:49.474798 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,473 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: Nuacht RTÉ', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:54:49.471597 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,470 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:54:49.469986 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,469 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: Nuacht RTÉ', Image=True
2025-10-28 17:54:49.469523 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,468 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 17:54:49.468563 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,467 INFO [uc_intg_skyq.media_player]   title: Nuacht RTÉ
2025-10-28 17:54:49.468563 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,466 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 17:54:49.466496 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,465 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='e9248953-1d8c-4123-a462-30bf8e1d1d2e', starttime=datetime.datetime(2025, 10, 28, 17, 40, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 17, 55, tzinfo=datetime.timezone.utc), title='Nuacht RTÉ', synopsis='Príomhscéalta an lae ó Nuacht RTÉ. (HD)', season=None, episode=None, image_url='https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-55a')
2025-10-28 17:54:49.462248 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,461 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 17:54:49.461211 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,460 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 17:54:49.460365 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,459 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 17:54:49.365832 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,365 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 17:54:49.364985 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,364 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 17:54:49.364126 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,363 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 17:54:49.325630 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,324 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 17:54:49.324967 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,323 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 17:54:49.323848 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,322 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 17:54:49.065262 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:49,064 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:54:39.064414 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,063 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: Nuacht RTÉ', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:54:39.061732 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,060 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:54:39.061732 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,059 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: Nuacht RTÉ', Image=True
2025-10-28 17:54:39.061732 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,058 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 17:54:39.061732 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,057 INFO [uc_intg_skyq.media_player]   title: Nuacht RTÉ
2025-10-28 17:54:39.061732 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,056 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 17:54:39.056179 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,055 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='e9248953-1d8c-4123-a462-30bf8e1d1d2e', starttime=datetime.datetime(2025, 10, 28, 17, 40, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 17, 55, tzinfo=datetime.timezone.utc), title='Nuacht RTÉ', synopsis='Príomhscéalta an lae ó Nuacht RTÉ. (HD)', season=None, episode=None, image_url='https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-55a')
2025-10-28 17:54:39.051142 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,049 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 17:54:39.050376 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,048 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 17:54:39.048352 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,047 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 17:54:39.007147 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,006 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 17:54:39.006252 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,005 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 17:54:39.005142 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:39,004 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 17:54:38.973343 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:38,972 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 17:54:38.972417 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:38,971 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 17:54:38.971565 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:38,970 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 17:54:38.883115 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:38,882 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:54:35.200661 +00:00	core	NOTICE	Setting rgb button backlight to: (255, 255, 255)
2025-10-28 17:54:35.199341 +00:00	core	NOTICE	Enter normal mode: standby in 176s
2025-10-28 17:54:29.387169 +00:00	ui	WARN	libpng warning: iCCP: known incorrect sRGB profile
2025-10-28 17:54:29.276558 +00:00	ui	WARN	libpng warning: iCCP: known incorrect sRGB profile
2025-10-28 17:54:28.880954 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,880 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'RTÉ One HD: Nuacht RTÉ', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: 'https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:54:28.879176 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,878 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:54:28.878690 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,877 INFO [uc_intg_skyq.media_player] SUCCESS: Title='RTÉ One HD: Nuacht RTÉ', Image=True
2025-10-28 17:54:28.877776 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,877 INFO [uc_intg_skyq.media_player]   image_url: https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ
2025-10-28 17:54:28.877776 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,876 INFO [uc_intg_skyq.media_player]   title: Nuacht RTÉ
2025-10-28 17:54:28.877776 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,876 INFO [uc_intg_skyq.media_player]   channelname: RTÉ One HD
2025-10-28 17:54:28.876454 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,875 INFO [uc_intg_skyq.media_player] current_programme: Programme(programmeuuid='e9248953-1d8c-4123-a462-30bf8e1d1d2e', starttime=datetime.datetime(2025, 10, 28, 17, 40, tzinfo=datetime.timezone.utc), endtime=datetime.datetime(2025, 10, 28, 17, 55, tzinfo=datetime.timezone.utc), title='Nuacht RTÉ', synopsis='Príomhscéalta an lae ó Nuacht RTÉ. (HD)', season=None, episode=None, image_url='https://imageservice.sky.com/pd-image/e9248953-1d8c-4123-a462-30bf8e1d1d2e/16-9/1024?territory=GB&provider=SKY&proposition=SKYQ', channelname='RTÉ One HD', status='LIVE', eid='Eb00-55a')
2025-10-28 17:54:28.873713 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,873 INFO [uc_intg_skyq.media_player] === STEP 4: Getting programme for SID 2816 ===
2025-10-28 17:54:28.873172 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,872 INFO [uc_intg_skyq.media_player]   live: True, sid: 2816
2025-10-28 17:54:28.872553 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,871 INFO [uc_intg_skyq.media_player] current_media: Media(channel='RTÉ One HD', channelno='101', image_url='https://imageservice.sky.com/logo/skychb_2816rtéonehd/600/600?territory=GB&provider=SKY&proposition=SKYQ', sid=2816, pvrid=None, live=True)
2025-10-28 17:54:28.800837 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,800 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 17:54:28.800333 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,799 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 17:54:28.799814 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,799 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 17:54:28.741738 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,741 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 17:54:28.741190 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,740 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 17:54:28.740611 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,739 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 17:54:28.421431 +00:00	ui	WARN	libpng warning: iCCP: known incorrect sRGB profile
2025-10-28 17:54:28.329084 +00:00	ui	WARN	libpng warning: iCCP: known incorrect sRGB profile
2025-10-28 17:54:28.122704 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:28,122 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:54:27.642909 +00:00	ui	WARN	libpng warning: profile matches sRGB but writing iCCP instead
2025-10-28 17:54:27.642486 +00:00	ui	WARN	libpng warning: known incorrect sRGB profile
2025-10-28 17:54:26.645723 +00:00	core	NOTICE	Setting rgb button backlight to: (0, 0, 0)
2025-10-28 17:54:26.645121 +00:00	core	NOTICE	Enter idle mode: standby in 166s
2025-10-28 17:54:26.165662 +00:00	ui	INFO	uc.ui.input: TAKE CONTROL FROM "MainContainer_QMLTYPE_234(0x55aaadbdc0)" -> "Activity_QMLTYPE_242(0x55aaf2b600)"
2025-10-28 17:54:26.048982 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: NEXT -> {"cmd_id":"fastforward","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.048839 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: PLAY -> {"cmd_id":"play","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.048732 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: STOP -> {"cmd_id":"stop","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.048617 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: PREV -> {"cmd_id":"rewind","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.048455 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: MENU -> {"cmd_id":"i","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.048315 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: RECORD -> {"cmd_id":"record","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.048106 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: MUTE -> {"cmd_id":"MUTE_TOGGLE","entity_id":"uc.main.81b51c28-56a2-47ca-a973-5da3ada03e81","params":{}}
2025-10-28 17:54:26.047922 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: CHANNEL_DOWN -> {"cmd_id":"channeldown","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.047745 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: CHANNEL_UP -> {"cmd_id":"channelup","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.047593 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_DOWN -> {"cmd_id":"down","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.047385 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_RIGHT -> {"cmd_id":"right","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.047139 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_MIDDLE -> {"cmd_id":"select","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.046900 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_LEFT -> {"cmd_id":"left","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.046672 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_UP -> {"cmd_id":"up","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.046484 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: VOLUME_DOWN -> {"cmd_id":"media_player.volume_down","entity_id":"hass.main.media_player.lg_webos_tv_oled55c34la","params":{}}
2025-10-28 17:54:26.046194 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: VOLUME_UP -> {"cmd_id":"media_player.volume_up","entity_id":"hass.main.media_player.lg_webos_tv_oled55c34la","params":{}}
2025-10-28 17:54:26.045846 +00:00	ui	INFO	qml: Watch SKY TV button mapping long press: POWER -> {"cmd_id":"macro.run","entity_id":"uc.main.d9f958c1-b6ee-4256-877b-7fdb975b53a2","params":{}}
2025-10-28 17:54:26.045459 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: HOME -> {"cmd_id":"home","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.044951 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: BACK -> {"cmd_id":"backup","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:26.037153 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:26.016824 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.993543 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.981244 +00:00	ui	INFO	qml: Setting up button mappings for activity: Watch SKY TV
2025-10-28 17:54:25.935151 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.934884 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:632: TypeError: Cannot read property 'icon' of null
2025-10-28 17:54:25.934387 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:644: TypeError: Cannot read property 'name' of null
2025-10-28 17:54:25.931339 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.918677 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:632: TypeError: Cannot read property 'icon' of null
2025-10-28 17:54:25.918282 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:644: TypeError: Cannot read property 'name' of null
2025-10-28 17:54:25.915181 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.914888 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:632: TypeError: Cannot read property 'icon' of null
2025-10-28 17:54:25.914441 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:644: TypeError: Cannot read property 'name' of null
2025-10-28 17:54:25.898833 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.883350 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.879753 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.865553 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.865178 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:632: TypeError: Cannot read property 'icon' of null
2025-10-28 17:54:25.862939 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:644: TypeError: Cannot read property 'name' of null
2025-10-28 17:54:25.845865 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.845612 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:632: TypeError: Cannot read property 'icon' of null
2025-10-28 17:54:25.845146 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:644: TypeError: Cannot read property 'name' of null
2025-10-28 17:54:25.828272 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.825838 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.794974 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.792340 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.758731 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.757004 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.685980 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.569869 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: NEXT -> {"cmd_id":"fastforward","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.569740 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: PLAY -> {"cmd_id":"play","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.569621 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: STOP -> {"cmd_id":"stop","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.569448 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: PREV -> {"cmd_id":"rewind","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.569315 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: MENU -> {"cmd_id":"i","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.569205 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: RECORD -> {"cmd_id":"record","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.569046 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: MUTE -> {"cmd_id":"MUTE_TOGGLE","entity_id":"uc.main.81b51c28-56a2-47ca-a973-5da3ada03e81","params":{}}
2025-10-28 17:54:25.568845 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: CHANNEL_DOWN -> {"cmd_id":"channeldown","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.568745 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: CHANNEL_UP -> {"cmd_id":"channelup","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.568639 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_DOWN -> {"cmd_id":"down","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.568514 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_RIGHT -> {"cmd_id":"right","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.568397 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_MIDDLE -> {"cmd_id":"select","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.568239 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_LEFT -> {"cmd_id":"left","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.568096 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: DPAD_UP -> {"cmd_id":"up","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.567903 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: VOLUME_DOWN -> {"cmd_id":"media_player.volume_down","entity_id":"hass.main.media_player.lg_webos_tv_oled55c34la","params":{}}
2025-10-28 17:54:25.567780 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: VOLUME_UP -> {"cmd_id":"media_player.volume_up","entity_id":"hass.main.media_player.lg_webos_tv_oled55c34la","params":{}}
2025-10-28 17:54:25.567605 +00:00	ui	INFO	qml: Watch SKY TV button mapping long press: POWER -> {"cmd_id":"macro.run","entity_id":"uc.main.d9f958c1-b6ee-4256-877b-7fdb975b53a2","params":{}}
2025-10-28 17:54:25.567480 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: HOME -> {"cmd_id":"home","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.567262 +00:00	ui	INFO	qml: Watch SKY TV button mapping short press: BACK -> {"cmd_id":"backup","entity_id":"uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006","params":{}}
2025-10-28 17:54:25.482163 +00:00	ui	INFO	uc.ui.input: RELEASE CONTROL BACK TO -> "MainContainer_QMLTYPE_234(0x55aaadbdc0)"
2025-10-28 17:54:25.480327 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.451655 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.420478 +00:00	ui	INFO	qml: Setting up button mappings for activity: Watch SKY TV
2025-10-28 17:54:25.336712 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.320478 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.268181 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:25.236955 +00:00	ui	WARN	qrc:/components/TouchSlider.qml:120: TypeError: Cannot read property 'volume' of null
2025-10-28 17:54:25.235560 +00:00	ui	WARN	qrc:/components/TouchSlider.qml:149: TypeError: Cannot read property 'volume' of null
2025-10-28 17:54:25.222837 +00:00	ui	WARN	qrc:/components/TouchSlider.qml:162: TypeError: Cannot read property 'name' of null
2025-10-28 17:54:25.222550 +00:00	ui	WARN	qrc:/components/entities/activity/deviceclass/Activity.qml:672: TypeError: Cannot read property 'hasFeature' of null
2025-10-28 17:54:25.216913 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:23.728008 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:23.725623 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:23.697730 +00:00	ui	INFO	qml: Activity state changed to: On
2025-10-28 17:54:23.671151 +00:00	core	NOTICE	[uc.main.4b047165-21f9-431d-881a-363d7313653a] activity 'Watch SKY TV' is running and preventing device standby
2025-10-28 17:54:23.670955 +00:00	core	NOTICE	[Watch SKY TV] activity finished
2025-10-28 17:54:23.669808 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:23,669 DEBUG [ucapi.api] [('127.0.0.1', 41660)] ->: {'kind': 'resp', 'req_id': 23, 'code': 200, 'msg': 'result', 'msg_data': {}}
2025-10-28 17:54:23.669293 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:23,668 INFO [uc_intg_skyq.remote] Command 'backup' sent successfully to SkyQ Device (192.168.0.150)
2025-10-28 17:54:23.580511 +00:00	ui	INFO	qml: Current step changed: undefined
2025-10-28 17:54:23.578919 +00:00	ui	INFO	qml: Activity state changed to: Running
2025-10-28 17:54:23.569276 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:23,568 DEBUG [ucapi.api] [('127.0.0.1', 41660)] <-: {"kind":"req","id":23,"msg":"entity_command","msg_data":{"cmd_id":"send_cmd","entity_id":"skyq_remote_skyq_192_168_0_150_9006","entity_type":"remote","params":{"command":"backup"}}}
2025-10-28 17:54:23.561982 +00:00	core	NOTICE	[Watch SKY TV] activity command: uc_intg_skyq.main.skyq_remote_skyq_192_168_0_150_9006:backup
2025-10-28 17:54:23.055770 +00:00	ui	INFO	qml: Current step changed: undefined
2025-10-28 17:54:23.052983 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:23.052428 +00:00	ui	INFO	qml: Activity state changed to: Running
2025-10-28 17:54:23.042281 +00:00	core	NOTICE	[Watch SKY TV] activity command: uc.main.81b51c28-56a2-47ca-a973-5da3ada03e81:INPUT_HDMI_1
2025-10-28 17:54:18.121417 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,120 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.PLAYING: 'PLAYING'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: 'Live TV', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:54:18.120432 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,120 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:54:18.119930 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,119 INFO [uc_intg_skyq.media_player] Using fallback: Live TV
2025-10-28 17:54:18.119815 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,119 WARNING [uc_intg_skyq.media_player] get_current_media returned None
2025-10-28 17:54:18.119544 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,119 INFO [uc_intg_skyq.media_player] current_media: None
2025-10-28 17:54:18.097143 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,096 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 17:54:18.096683 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,095 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 17:54:18.095402 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,094 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 17:54:18.046070 +00:00	ui	INFO	qml: Current step changed: undefined
2025-10-28 17:54:18.043916 +00:00	ui	INFO	qml: Activity state changed to: Running
2025-10-28 17:54:18.041828 +00:00	core	NOTICE	[Watch SKY TV] activity delay: 5000 ms
2025-10-28 17:54:18.039597 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,039 DEBUG [ucapi.api] [('127.0.0.1', 41660)] ->: {'kind': 'resp', 'req_id': 22, 'code': 200, 'msg': 'result', 'msg_data': {}}
2025-10-28 17:54:18.038934 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,038 INFO [uc_intg_skyq.media_player] Using fallback: Live TV
2025-10-28 17:54:18.038609 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,038 WARNING [uc_intg_skyq.media_player] get_current_media returned None
2025-10-28 17:54:18.038279 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,037 INFO [uc_intg_skyq.media_player] current_media: None
2025-10-28 17:54:18.027551 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,026 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 17:54:18.026564 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,025 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 17:54:18.024459 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:18,023 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 17:54:17.920770 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:17,919 INFO [uc_intg_skyq.media_player] === In EPG - Getting live media ===
2025-10-28 17:54:17.919820 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:17,918 INFO [uc_intg_skyq.media_player]   appId: com.bskyb.epgui, title: EPG_UI
2025-10-28 17:54:17.918807 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:17,917 INFO [uc_intg_skyq.media_player] Active app: App(appId='com.bskyb.epgui', title='EPG_UI')
2025-10-28 17:54:17.887659 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:17,884 INFO [uc_intg_skyq.media_player] === STEP 2: Getting active application ===
2025-10-28 17:54:17.887659 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:17,883 INFO [uc_intg_skyq.media_player] Device is ON
2025-10-28 17:54:17.883557 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:17,882 INFO [uc_intg_skyq.media_player] Power status: is_standby=False
2025-10-28 17:54:17.099694 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:17,098 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:54:16.563489 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:16,562 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:54:14.492536 +00:00	ui	INFO	uc.ui.input: TAKE CONTROL FROM "MainContainer_QMLTYPE_234(0x55aaadbdc0)" -> "LoadingScreen_QMLTYPE_95(0x55aa57c820)"
2025-10-28 17:54:14.485481 +00:00	ui	WARN	uc.ui.resources: Empty ID passed to getIcon()
2025-10-28 17:54:14.484652 +00:00	ui	INFO	qml: Current step changed: undefined
2025-10-28 17:54:14.482444 +00:00	ui	INFO	qml: Activity state changed to: Running
2025-10-28 17:54:14.444983 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:14,443 DEBUG [ucapi.api] [('127.0.0.1', 41660)] <-: {"kind":"req","id":22,"msg":"entity_command","msg_data":{"cmd_id":"on","entity_id":"skyq_media_skyq_192_168_0_150_9006","entity_type":"media_player","params":{}}}
2025-10-28 17:54:14.440124 +00:00	core	NOTICE	[Watch SKY TV] activity command: uc_intg_skyq.main.skyq_media_skyq_192_168_0_150_9006:media_player.on
2025-10-28 17:54:14.129284 +00:00	ui	INFO	qml: Current step changed: undefined
2025-10-28 17:54:14.128300 +00:00	ui	INFO	qml: Activity state changed to: Running
2025-10-28 17:54:14.117900 +00:00	core	NOTICE	[Watch SKY TV] activity command: uc.main.81b51c28-56a2-47ca-a973-5da3ada03e81:remote.on
2025-10-28 17:54:14.117461 +00:00	core	NOTICE	Added standby inhibitor: Active activity 'Watch SKY TV'
2025-10-28 17:54:14.116828 +00:00	core	NOTICE	Started activity 'Watch SKY TV' (uc.main.4b047165-21f9-431d-881a-363d7313653a) with timeout of 60s
2025-10-28 17:54:14.114889 +00:00	core	NOTICE	Starting activity 'Watch SKY TV' (uc.main.4b047165-21f9-431d-881a-363d7313653a) in activity group: 'TV activities group' (e70ce414-550d-4990-b96e-af12fa6d88e3)
2025-10-28 17:54:13.434724 +00:00	core	NOTICE	Changed battery status: 100% Discharging, 4110mV, charger: false
2025-10-28 17:54:08.605489 +00:00	core	NOTICE	Added standby inhibitor: Web configurator
2025-10-28 17:54:08.433369 +00:00	core	NOTICE	Added standby inhibitor: charger
2025-10-28 17:54:08.430141 +00:00	core	NOTICE	Changed battery status: 100% Not charging, 4160mV, charger: false
2025-10-28 17:54:07.099431 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:07,097 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:54:07.095646 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:07,094 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:54:07.094288 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:07,093 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:54:07.093002 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:07,091 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:54:06.471126 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:54:06,469 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:54:03.584765 +00:00	core	NOTICE	Setting rgb button backlight to: (255, 255, 255)
2025-10-28 17:54:03.583347 +00:00	core	NOTICE	Enter normal mode: standby in 176s
2025-10-28 17:53:56.469927 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:56,468 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:53:56.466736 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:56,465 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:53:56.465145 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:56,464 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:53:56.464156 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:56,463 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:53:56.375612 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:56,374 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:53:46.375462 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:46,373 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:53:46.371966 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:46,371 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:53:46.370540 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:46,369 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:53:46.369768 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:46,368 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:53:45.989386 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:45,988 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:53:35.987945 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:35,986 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:53:35.984772 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:35,983 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:53:35.982757 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:35,981 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:53:35.981600 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:35,980 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:53:35.889670 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:35,888 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:53:25.889474 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:25,888 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:53:25.886379 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:25,885 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:53:25.884784 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:25,884 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:53:25.883865 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:25,882 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:53:25.744774 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:25,743 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:53:15.742553 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:15,741 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:53:15.739453 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:15,738 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:53:15.737730 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:15,736 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:53:15.736784 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:15,735 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:53:15.550147 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:15,549 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:53:05.549077 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:05,547 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:53:05.545954 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:05,545 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:53:05.544459 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:05,543 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:53:05.543537 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:05,542 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:53:05.457299 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:53:05,456 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:52:55.457383 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:55,455 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:52:55.454210 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:55,453 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:52:55.452640 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:55,451 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:52:55.451569 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:55,450 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:52:55.364325 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:55,363 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:52:45.361840 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:45,360 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:52:45.358601 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:45,357 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:52:45.357185 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:45,356 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:52:45.356362 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:45,355 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:52:45.065788 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:45,064 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:52:35.064996 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:35,063 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:52:35.061831 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:35,060 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:52:35.060311 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:35,059 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:52:35.059366 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:35,058 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:52:34.951295 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:34,950 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:52:24.948716 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:24,947 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:52:24.945528 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:24,944 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:52:24.943857 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:24,943 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:52:24.942890 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:24,941 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:52:24.850338 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:24,849 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:52:14.849468 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:14,847 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:52:14.846160 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:14,845 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:52:14.844660 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:14,843 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:52:14.843875 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:14,842 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:52:14.579449 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:14,578 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:52:04.579004 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:04,577 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:52:04.575865 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:04,574 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:52:04.574190 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:04,573 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:52:04.573242 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:04,572 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:52:04.488100 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:52:04,487 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:51:54.486348 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:54,484 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:51:54.482977 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:54,481 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:51:54.481290 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:54,480 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:51:54.480339 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:54,479 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:51:54.392897 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:54,391 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:51:44.391613 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:44,390 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:51:44.388491 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:44,387 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:51:44.386887 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:44,386 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:51:44.385949 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:44,384 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:51:44.236502 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:44,235 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:51:34.236575 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:34,235 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:51:34.233453 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:34,232 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:51:34.231465 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:34,230 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:51:34.230292 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:34,229 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:51:34.139583 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:34,138 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:51:24.138081 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:24,136 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:51:24.134799 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:24,133 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:51:24.133142 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:24,132 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:51:24.132110 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:24,131 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:51:24.040903 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:24,039 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:51:14.040202 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:14,038 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
2025-10-28 17:51:14.037127 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:14,036 DEBUG [ucapi.entities] [configured]: entity 'skyq_media_skyq_192_168_0_150_9006' attributes updated
2025-10-28 17:51:14.035599 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:14,034 INFO [uc_intg_skyq.media_player] Device in standby
2025-10-28 17:51:14.034645 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:14,033 INFO [uc_intg_skyq.media_player] Power status: is_standby=True
2025-10-28 17:51:13.914501 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:13,913 INFO [uc_intg_skyq.media_player] === STATUS UPDATE v1.0.41 - POLLING + FIXED COMMANDS ===
2025-10-28 17:51:03.911582 +00:00	custom-intg-uc_intg_skyq	INFO	2025-10-28 17:51:03,910 DEBUG [ucapi.api] [('127.0.0.1', 41660)] =>: {'kind': 'event', 'msg': <WsMsgEvents.ENTITY_CHANGE: 'entity_change'>, 'msg_data': {'entity_id': 'skyq_media_skyq_192_168_0_150_9006', 'entity_type': <EntityTypes.MEDIA_PLAYER: 'media_player'>, 'attributes': {<Attributes.STATE: 'state'>: <States.OFF: 'OFF'>, <Attributes.VOLUME: 'volume'>: 50, <Attributes.MUTED: 'muted'>: False, <Attributes.MEDIA_TITLE: 'media_title'>: '', <Attributes.MEDIA_IMAGE_URL: 'media_image_url'>: '', <Attributes.MEDIA_TYPE: 'media_type'>: 'channel', <Attributes.MEDIA_DURATION: 'media_duration'>: 0, <Attributes.MEDIA_POSITION: 'media_position'>: 0}}, 'cat': <EventCategory.ENTITY: 'ENTITY'>}
Hey, i just released version 1.1.1 with a potential fix to your issues. Go ahead and test it out. thank you.
