R3 Phantom touches
Recently got a Remote 3. After the remote is on for a bit, it will start registering touches on the touch screen. This will usually cause the source to repeatedly play/pause or the volume to go up and down quickly.
Has anyone else seen this behavior? Do I have bad hardware? Is there some kind of calibration that can be run?
There was a similar issue but it has not been solved: My R3 is possessed!
You should contact the support.
