Macros for IR Commands
Hi there, i’m just playing around to migrate from my Harmony Elite environment.
In my setup i have one page for the activity “Watch TV” where i have a page with my favorite Channels.
How can i add a Macro to such a channel, for instance the channel Pro7 is expecting the following commands “1”+“2”+“OK” as it’s channel 12 in my TV.
I saw already that this would be a Macro, but i can’t add it to the Icon for that Channel :confused:
Is this not possible yet? Or how can i combine more commands for such a use case?
Thanks!
Nobody an idea how this is working?
@marton : I know you’re quite busy with shipping and getting everything ready. Is this planned that Macro’s can be used for favorites?
Ok found it myself after 2h of searching.
So the Macros can be reused in activities, therefore i’ve created a activity for “Watch TV” where i then have a page for ma TV Sender favorites.
Here is one example for a Macro:
Then you can add this newly created Macro as an entity inside the activity:
And after that you can also add the macro itself as a command for the TV sender:
Hope for somebody else it’s also helpful and for sure a time saver :slight_smile:
Nice, where can i download the icons (90x90px)? Cant find the right size.
I have downloaded them from that page TV-Senderlogos (Picons) zum herunterladen - smooth ones and convertet them with Imagemick to 90x90
Ive followed your instructions but for all the channels ive added (each with two digits) only the very first one i added seems to work. The others dont seem to register either the first or second digit and even putting various delays doesnt seem to help. Has anybody come across this and found a workaround?
Since one of the last updates you can use ir sequences instead of macros. They just appear as additional commands for each ir entity. Just enter all commands an separate them with a comma. You can also define the delay between each command. This works well for me.
I wish I had seen this earlier today before I created a macro for each station :joy:
Thank you so much!!!
Like @leo if only the remote designers had supplied some up to date instructions or new short videos I too wouldnt have wasted hours creating macros for every bloody TV double digit requirement!!!
However, this IR sequence option doesnt seem to show up if I go into the specific IR remote (entity) settings
This particular TV was chosen from the generic list inside Remote Two.
The option only appears if I want to edit inside an Activity, which is fine, but I also want to have every function, including direct channels available in the device selection itself (I have a page called ACTIVITIES but also a page just called DEVICES that gives quick access to the functions of each device I have, or “entity” as its known here.
Make sense?
I’ll get your point on the device section, but as Macros or IR Sequenses only work in Activities, maybe you can workaround with creating an Activity with just the device and without start sequenz for that purpose
Hello Kenny,
I am also trying to send multiple IR codes to the TV in order to directly jump to channels 10 and higher. I have learned the commands from my original remote into the ‘Fernbedienungen’ section of the R2.
How can I add the makros or mulitple commands to the remote? Where can I find the editable ‘Kommandos’ entry that is shown on your screenshot.
Sorry but I am still learning to understand this device.
Finally, I wish to have a screen with all the channel logos on the screen, so that I can directly access them with a sinlge touch - even their number is greater than 9.
Thanks a ton,
senso
This should be visible inside the activity, when you have assigned a IR device to that one
But you can also define your favorite channels as macro and assign the macros as entities to the activity, this is how i did it. Also works like a charm.
You can see it in my previous post Macros for IR Commands - #3 by Freshhat
I created some kind of comic for the steps you need to make:
  1. Create or select an activity
  2. select edit user interface
  3. drag the circled screen to a field on the display
  4. press on screen
    4 press on screen
  5. select custom icon
  6. select or upload a 90x90 pixel icon
  7. select IR sequence of IR device
  8. Enter channel number of TV station. Sometimes it is simply 1 sometimes DIGIT_1 depending on device. You can also add OK, SELECT or ENTER to speed things up depending on device.
    8 enter channel number sometime 1 and sometimes DIGIT_1 depends on device
btw. a good source of icon in europe is looking for “snp picon” these are collections of icons for Enigma2 STBs. snp means service name picons so they use the channel names for the icons. They are rectangular and must be changed for the R2.
