LG WebOS Integration - How?
If the integration fails after 1st setup you must reinstall it at least with firmware <2.8.2.
How far did you get during setup? Did it find your TV or did you enter IP? If you came beyond this point you must see the TV picture and you must confirm TWICE that control is allowed.
I have uninstalled and reinstalled each time. I typed in the ip address.
Remote firmware version is now 2.8.2 (just updated)
And I tried again without reloading. (LZG TV was powered off)
“Something went wrong while setting up the integration.
NOT_FOUND”
Uninstalled, reinstalled: uc-intg-lgtv-v1.13.2-aarch64-20260114_115521.tar.gz
Tried again (with auto discovery.) Finds [LG]webOS TV OLED55E6P 192.168.1.55
Oops!
CONNECTION_REFUSED
TIA for any help
Check the integration readme if you enabled all needed settings on the TV. Your TV also needs to be on to complete the setup. Otherwise please post the logs on Discord in the matching community-projects thread for the LG integration.
All options on the TV are set.
Sorry I don’t know where to find the LG integration community-projects thread. I have been all over the net the last few weeks trying to get the U3 to work.
Please provide details about how to post the logs. No one has responded to let me know.
As an aside, the remote does communicate with the Denon AVR
Thank you for the help
Download logs: Settings/Development/logs and choose the LG integration from the dropdown.
(This info can be found in a lot of threads here by a simple search)
yes. I knew how to download the logs to my system. The question I have is where/how to upload them for investigation
Sorry my question wasn’t clear
Post them in the linked thread on Discord
I have uploaded the logs. Hope that helps determine the issue
Sort of weird that the Sofabatons work fine without enabling “LG Connect Apps” on the LG OLED. Would be nice if the integration could be modified to work the same as the Sofabaton
Use Bluetooth as Sofabaton. It was written several times that Sofabaton uses either Bluetooth or IR.
But I have never paired my Sofabatons using BT with the TV
And I tried using IR with the Unfolded. It never worked
