I am on 26.2 but it should not make a difference.
Have you used finder to look at your downloads folder?
uc-intg-lgtv-v1.11.0-aarch64-20251126_103512.tar.gz is what I get
yes I go into Finder and it has lost the .gz. When I rename it the Web configurator accepts it but then I get the error message âinvalid archive, missing dataâ etc. I have just received my remote today and I am used to the Logitech but I thought I would give this a try but I have spent the whole afternoon trying to get this done. So feeling a little bit of buyers remorse as have not really achieved anything. Thanks for your time.
I received mine a week ago. Have spent many hours trying to get anything to work (LG OLED. Apple 4k TV, Denon AVR).
Try running the terminal app. cd to the downloads folder. See if the issue is with finder
This is what is downloaded âuc-intg-lgtv-v1.11.0-aarch64-20251126_103512.tarâ every time I try to download it
Notice my file name ends in .gz
Are you using Safari to download?
Yes I am using Safari. How do I use the terminal app. I have launched it and typed in cd downloads, but how do I see the contents of the download folder?
ls -al is the command
yikes there is a lot of entries here. Canât make head or tails of it
Do you think updating the OS might help?
https://linuxize.com/post/how-to-list-files-in-linux-using-the-ls-command/
use ls -alt
Sorts by time
And the OS
try ls -alt uc*
Itâs amazing you have the same system as me. I have used the integrations that unfolded created and they worked like a dream. Found my marantz processor and my AppleTV but am now stuck on the LG OLED.
Using the last command you have given me it displays exactly what Finder has. No .gz
Make sure you have finder showing extensions.. Show all filename extensions
Show all file extensions, even for files that have âHide extensionâ selected
Let me check some more. Looks like you have the system set to unpack files
To stop Safari on macOS from automatically unpacking downloaded zip files, go to Safari Preferences, click on the General tab, and uncheck the option âOpen âsafeâ files after downloading.â This will allow zip files to download without being automatically unzipped
Do you have any other browsers installed?
Instead of left click on link the right click with choosing download from menu might also work.
I think I need to start from scratch. Error on remote: Connection to dock not established for one of my activities.
And I still do not know how to upload my logs
