Integration ideas?
Thank you for the kind words, appreciate it.
JVC np5 projector, Emotiva RMC-1 PROCESESS
there is already jvs integration and i do not have emotiva, hard to build for devices i dont own :slight_smile:
so nanoleaf is done, govee is done, smartthings is done, nzb is done, even a random one like NASA. Any other cool ideas? I am trying to think creatively but running into “writers block” lol.
Have you thought about an alternative Hue integration that supports more features like scenes? The build in integration is very limited in that way and also spams the log with ongoing requests for all light. I think it’s still using an outdated Hue API.
Moonraker to monitor 3D printers?
i am eying really bad a bamboo printer, once i get it i will 1000% going to do an integration for 3D printer.
i did not, i don’t have hue and i assumed native integrations are much more superior from anything i would do lol. can look into that, but i will need to simulate as i dont have any hue lights.
i am thinking of doing a Synology integration. i am a HEAVY user of synology. wondering if it just me tho lol
I love how you’re excited about making integrations, haha. That’s really cool to see.
Thank you so much @cobhc , i do enjoy it - i like the creative approach for it. unlike Harmony, this remote does allow for more creativeness for sure
You are not alone. My DS 920+ is my castle.
Awesome. Cause I started lol.
Hello,
thanks for your integrations done so far.
Would be great having direct support for Camilladsp. (like volume control, aux faders etc.)
Installation scripts for various platforms:
or
There is a home assistant integration for Camilladsp already existing:
but would be nice to have it supported directly.
Edit: Links fixed
I would love to have a HEOS integration for multi room audio, and Switchbot for controlling my curtains. I do own a Homey, but some things are either limited (only play/pause, volume and skip for HEOS speaker) or impossible (no curtain control at the moment). Would be great to have these!
An integration for the Eversolo DMP streamers would be good.
The Lyngdorf family of multichannel processors (MP60 etc). The HA integration is available here
I am surprised that, apart from Trinnov, there is no support for any high end HT processors like this Lyngdorf.
Hi M.a.S.e, I haven’t received my Remote 3 yet but would love a Synology/DSM integration to add to the remote as I use it a lot, Cheers.
i am working on Synology right now.
as for the other devices, its really hard to build an integration without having the physical device on my local network, i need to test it in dev to see what works/how to make it work before i package it up, so a little challenging without having the device or it being an online service. i do have Marantz so i can look into HEOS however i thought that is already supported by UC.
great would be also support for BEQ:
with access to ezbeq in some way or directly to data bases underneath.
Being able to select filter sets for movies from R2/3 directly would be really cool. Example:
