Integration ideas?
I completely forgot about it needing MQTT. That makes complete sense now.
thanks for the ideas, if there is an HA one it makes it a lot easier, however its really hard without having the device, to test we will need to be on the same network, before i get to a point of building the actual integration for the remote i run it in local dev and do the tests, if i were to have someone else test i would need to package it with each test which is doable but makes it a nightmare. :frowning:
No worries, totally understand and really appreciate all of the work you have done already! Happy to help if I can; I didn’t know if it might just be a case of repackaging the Eversolo HA integration for the remote and then testing it, but as you say it might be too much effort without the hardware.
I like an intergration, if possible, of Tuya zigbee devices like smart curtains
Tuya might be possible, i have some Tuya devices laying around so i can test. will look into that.
Ah would be great, thank you in advance
One idea for an integration is Nanoleaf stuff? Again, it’s already supported in HA, but a built-in integration would be preferred.
I have a single nanoleaf device, I think I can do that.
Hello. Do you own a homey? On this moment there is a homey integration that let homey start a flow and thereby do a action. But i would like that homey could start a activity on the remote or send a signal for a device. Or webhook.
I do not sadly :frowning:
Too bad. But thanks anyway.
Anyone got Nanoleaf devices and is willing to help me test a new integration, maybe?
Nanoleaf integraion complete: Nanoleaf integration
I love the idea of integrations that can’t already be provided by Home Assistant. That said I’m sure there are users of R3 that don’t use Home Assistant, so for them it may be important.
For me? I love the idea of Sonarr, Radarr, Overseerr, and SabNZBd as integrations.
Out of interest, why are you using SABnzbd as opposed to NZBGet?
Because NZBGet was abandoned by its creator a while back. Its finally been forked and picked up again, but I made the switch to SabNZBd in the meantime and haven’t had any reason to switch back. SabNZBd works great for me.
I went the other way. From SABnzbd to NZBGet.
working on uc-intg-nzbinfo. fyi
integration ready; NZB Info Management
Your Integrations are amazing, thanks for sharing!!!
