Integration ideas?
In this instance, I hadn’t thought about it this way. I’m sure you are right on this. I moved from Homeseer to Home Assistant for the sole reason of HA’s support for the remote 3.
I’m also a Home Connect user. But what function would be useful to use with the remote control? A notification when the washing machine is finished? Or controlling the stove with the remote?
Notifications and controlling like we do we the Home Connect app but it was just an extra if it was an easy task. Not that important. :slightly_smiling_face:
API documentation is available:
No one here is using BEQ?
Anthem integration complete : Anthem AV Integration
CCTV integration ready: CCTV Security Cameras Integration - #3 by M.a.S.e
Hi M.a.S.e.
I’m in germany and would like to have an integration for TechniSat STB’s.
Those STB’s can be controlled by their own App “TechniSat Connect”.
If you are interested in that and i can help you let me know.
Is possible an integration for the Cambridge Audio CXN100? :face_with_peeking_eye:
Just one more question:
Does anyone here has more than one AndroidTV box and is able to use the Android TV integration with all of them?
And do you use On and Off, or Toggle On/Off?
i need Cambridge Audio Testers - Please DM me or Find me on Discord please if interested.
Cambridge Audio integration done, no idea if it works tho as i dont own a cambridge audio device :slight_smile:
I’d also love a Panasonic TV (Viera) integration. Only some of the newer models are using Fire TV as OS. For those that don’t, something like the HA integration would be perfect. The models I’ve got are TX-49FX750B, TX-40EX700B & TX-24DS500B. I’d be happy to help test.
I would love to have an Philips HUE play wync box integration. There is one for HAS
But need to create helpers to use it and ideally i would have it directly commanded from the R4
Panasonic Viera is done.
And very good it is, too.
Does anyone have any inside knowledge of Comcast/Xfinity’s X1 cable boxes? It would be great to have IP control instead of just IR. But their system is closed pretty tight.
You should ask nicely to @M.a.S.e .
Tell him Harvey sent you!
Dream Player a android tv player for TVheadend server but also has a companion app for your mobile device for guide data. Not sure if the remote 3 can run android apps or if the developer would allow conversion to run on remote. But would be pretty cool to find and select what to watch directly from the remote?
