FireTV released: FireTV Integration - Direct IP (Not ADB/Bluetooth)
Any EMOTIVA users for a potential integration who are willing to test ? ( i do not own an EMOTIVA device).. if so, please DM Me or find me on discord please.
My remote arrives on Wednesday and i wanted to see if anyone can help me move from my Harmony Elite to the Remote 3.
This are the devices that i have on Harmony:
- Samsung S95D and Samsung Q8F (the existing integration should work)
- Phillips Hue Bridge (already there’s one)
- Samsung HW-Q990D (soundbar_BT)
- Xiaomi Mi Box S and Mi Box 2ndGen (certified Android TV; maybe the existing integration works with it)
- Vodafone tv box (is an Android TV box so it probably will work)
- Octagon SF8008 4K UHD E2 DVB-S2X Twin Sat (IR)
- Zgemma h.2h (IR_another Sat receiver)
- Emby
- Sony BDP-S570 (an old bluray player_IR)
- Micromega IA400 (music amp_IR)
- Roborock S7 MaxV
- Daikin Stylish (Wifi and IR_ The link is from Daikin US but i’m from Portugal; don’t know if there’s any difference)
And, if it’s possible, even not being truly important (i’m felling ridiculous now
- Siemens dishwasher IQ700 series - SN97YX01CE/08 (wifi using the app Home Connect)
- Siemens wall mounted cooker hood/chimney IQ700 series - LC91BUV50/04 (wifi using the app Home Connect)
- Siemens Induction hob IQ700 series - EX675JYW1E/14 (wifi using the app Home Connect)
Just an off-topic question for not create another topic):
So, in Harmony Elite We have “Activities” and “Devices”. On Remote 3 which ones correspond to these one?
Samsung Soundbar: if it works with smartthings you can test my smartthings integration
Emby - i created an integration for Emby already. Check my github.
LMAO on the dishwasher.
I usually take on projects that are interesting, there is an API for it and that more then 1 person have the device, otherwise - spending hours/days for a single person (especially when i cant test) is not helpful for the community. ![]()
To answer your question:
For the Unfolded Circle, there is an “Activities” and “Devices” sections which match 100% to the same (they even called the same), you need to build your own activities and if you want to see also all “devices”, create a main page called “Devices” and add all the entities you want there. to mimic the same.
Didn’t saw the integration for Emby; just Jellyfin. (only saw here).
There is one i forgot but don’t know if it’s possbile: Stremio (i have The Android TV version and the Tyzen version)
As for the Siemens appliances, yeah, i’ve gone too far on my excitement ![]()
Thanks!!!
Np. Check my github there’s about 30 integrations I’ve done, you might find them useful. If more folks say they have the devices you have i might take that on. This is done based on availability and how many people want. It’s not my job, just trying to help folks out. So if more people will ask, maybe that’s a cool project can take on ![]()
For your consideration @M.a.S.e I would love to see Lyngdorf processors supported. I believe I am the 3rd or 4th with a request. It’s also highly likely that this integration would also support the higher tier Macintosh processors as well as they use the Lyngdorf system under the hood. Interestingly Lyngdorf is out of Denmark also and have a very strong following in Europe so I would imagine there are others that use both products. In fact the remote actually looks like it was designed by Lyngdorf. Lastly, I would be more that happy to work with you as much as you need for any testing, resources etc.
do they have an API? or a home assistant integration?
There is a library available and a Home Assistant Integration. To be honest, the HA integration works very well. For discreet codes I use HA Node-Red and this works very well also. What I am really missing is the display of .5 db volume increments. I know UC doesn’t currently support this but I believe? it’s on their roadmap. My hope is that an integration would automatically reflect this? You would certainly know better than I.
Share links. So I can take a look.
Lyngdorf Libraries: GitHub - fishloa/lyngdorf: Python library to control a Lyngdorf Processor
HA Integration: GitHub - jsoutter/ha-lyngdorf: Home Assistant Lyngdorf Integration
Thanks for taking a look!
For Enigma2 use Dreambox integration.
The only way I know to control your Daikin AC is via the Home Assistant integration (assuming you have Home Assistant of course) I’m guessing the same would be true about your home connect devices although really not sure why you’d want to control those from your R3 ![]()
emotiva integration is done: Emotiva Integration
you would be surprised how many people don’t host their own HA server or dont want to deal with that (although the HA integration is the Unfolded biggest selling point).
If you are referring to me, regarding my Octagon SF8008, I’ll try.
Thanks ![]()
I have a 8008 myself among some VUs. Zgemma h.2halso can work with Enigma2.
Do you think that everyone uses HA?
Also, why not controlling the AC from the remote?
Not everyone uses HA but I suspect a lot of folks who bought the R3 do. No issue with controlling the AC through the remote (via HA) but I meant I wasn’t sure why you’d want to control things like your dishwasher through the remote.
My Siemens appliances they have several functions within the Home Connect app but, yes like i said:
