Sorry for late reply… I use the madVR Envy Extreme within my setup, but for IP-Control there ist no difference to the core-version.
Many thanks again @M.a.S.e for the integration. I will look into it asap (some work outside)… Until now i worked with simple commands on my own via the HA madVR integration. But native for UC R3/R2 would be much better😃
it works, but by default there are no commands within. You have to create your own simple commands with the API-documentation (from madshi, CTO madVR Labs).
It is able to power on the MadVR from an off state? (not standby)
I find it odd that the actual MadVR IR remote won’t power on the unit from off. It will power it on from standby, but not from off. So the integration @M.a.S.e is working on has to be able to wake the unit up using Wake-on-LAN which is a bugbear currently.
Yes. It is working by entering your envy`s MAC adress. For this you could also use WOL by @kennymc.c Integration. Both will work from off-state (but: it is possible, that your dealer has to enable the WOL-function within the BIOS-setup).
What about an integration with Proxmox VE for those that are hosting their own VMs or containers for Plex, Emby, Jellyfin etc… ? Something simple such as just starting and stopping the relevant VMs / Containers when a specific scene is selected
VM: Proxmox VE API Documentation
Sony Bravia integration would be awesome.The android one, isn’t great for Sony tv’s.I have home assistant, but would like it working as an integration if possible?
I do not think that is possible. On my Philips most TV functions are realized by normal apps. What is even more complicated is that UK free at is handled differently.
any plans adding direct support for CDSP?
Would of course help testing but setup is really easy with these scripts provided by Henrik.
(My whole home cinema runs with it with almost 20 output channels (xovers) with linear phase (FIR) filtering.)
Volume control makes most sense at the outputs from CDSP and not at the AVR (at the input to CDSP) and here UC remote comes into play.
I’m working right now on fire tv integration by direct ip (no adb or Bluetooth). Can look into all the other suggestions. But usually I pick those that at least 3 people want, if there is a documented api and someone who can dedicate themselves for testing. It’s very VERY hard to develop for devices I don’t have, since I can’t test it or debug. I’ll finish the fire tv and pick something new (barring some free time since I still have a mortgage to pay lol)
