Anthem AV Integration
Hello, i am releasing Anthem AV integration. integration should support most IP supported moduls. Support single or multi device with single or multi zone. Integration will create a media player entity per zone.
Power Control: On/Off/Toggle
Volume Control: Volume slider (-90dB to 0dB mapped to 0-100)
Volume Buttons: Up/Down with real-time feedback
Mute Control: Toggle, Mute, Unmute
Source Selection: Dropdown with all available inputs in activity
This is another blind integration, therefore i cannot test/replicate/validate.
any issue will require explicit problem statement and logs for further debug.
I also unable to test if initial release work. Please let me know if not.
Thank you.
PS - its best to join the discord channel as i am more active there.
Interesting. I will give this a spin with my AVM60. It’s working right now well enough over IR with a wired blaster, but I’ll give this a shot later in the week. Thanks for the upload.
Kevin T
