Hi UC community,
Having some issues with my dock. I had it nicely integrated in my config but needed to remove it. So far so good.
The dock still connects to my wifi, but re-adding give a error message “connection refused”. Going through the documentation’s reset steps does not do anything. The button on the plastic cover is unresponsive.
thanks for pitching in. I managed it. FInally. Found that the “button” at the back of the dock takes quite a bit of more time to hold then the 8 seconds mentioned in the documentation
I thought the reset button was the tiny hole on the bottom side of the dock, so I got a pin and pushed it through…I’m pretty sure the pen went through something it wasn’t supposed to. I understand this is a kickstarter product but they really need better documentation.
Update: I just noticed there is some documentation online and it shows the button on the top to reset. I guess I should have looked at that first but I was going with what was shown in the manual
