Connection to Dock Not Established?
I have recently be getting this error message sporadically (“connection to dock not established”). However, since it’s sporadic I’m not sure what’s causing it. Anyone have any ideas?
Try to connect the manually by using the ip instead of the mDNS domain as exlained here: https://support.unfoldedcircle.com/hc/en-us/articles/20018912602524-Manually-add-a-Dock-in-the-Web-Configurator
I followed the instructions but keep getting an error message. BTW - do you know how to set up a static IP address and also DHCP IP reservation?
You need to use your router to set a static ip or use DHCP reservation.
please see also:
