Hi, I have an XGIMI Horizon S Max. Is there any plan to work on their integration?
Someone on Discord tried a usb to serial bridge to use it with Home Assistant. But you should first check if the Android TV integration works with your model.
hi
can you give us an update for your case? did the android tv integration work for your xgmi projector?
