Xfinity X1 IR codes only work in edit mode
I downloaded the IR pronto codes from GlobalCache for my Xfinity X1 cable box. I paste the codes in the edit box and test them and they work. However, when I go back to the list of codes under the entity and send the code from there it does not work! Also, they do not work if I add them to a sequence of an activity.
I have two other entities I have added IR codes; an LG TV and Panasonic BluRay player and they work fine in all instances. Any ideas on what could be happening would be appreciated.
Michael
Did you define the correct output devices for the IR entity?
Thanks, that was it. It was correct in the IR edit function but not on the entity itself.
Michael
Hi Michael,
I’m trying to add an Xfinity X1 device as an entity for the Remote 3. I dowloaded Global Cache pronto codes but it does not work for me. can you help me?
