Wireless charging causing extreme heat
When I charge my remote 3 on a wireless charger, both the charger and remote get almost too hot to touch, this causes concern as I can’t leave it on the charger and leave the room. Has anyone else found this overheating issue? ps. this has happened with 2 different wireless chargers so I don’t think it’s a charger fault.
hi,
my remote gets hot too. but i think this is a normal behavior and you don’t need to worry about overheating or something like this.
Same for me
Hello group here, and unfolded team,
This will be an issue with the battery dying - the issue is the software in the remote is continuing to charge even at 100% - it needs to be smart and stop at 100% and not charge until discharged for a long while - maybe even monitor temp.
If the battery is charged the remote will still pull power from the power source to run its system. Some chargers might think that the device is still charging while it’s actually not.
Since 2.7.2 additional information has been added to the charging screen to indicate if the remote is charging or just connected to a power source.
Seems to be the case. The word ‘charging’ is then left out of the display. I can see in Home Assistant that it now seems to switch been charging and not charging without a continuous amount of time in between (sometimes seconds, sometimes minutes).
Could the degree of heat be related to the remote’s contact with the charger? As in, if there’s a small gap between the two perhaps it’s creating heat. Mine is fully in contact with its charger and I don’t get much heat to speak of.
Yes, same here. Extremely hot, not only in the area where the battery is located..
