WiiM High-Res Audio Streamer Currently Playing & Controls
Hello Everyone, i am releasing my WiiM integration.
If you are unfamiliar with WiiM products, WiiM is a brand of audio streaming devices that transforms existing audio systems into “smart” streaming setups (Think Sonos on Steroids for Audiphiles). Their product lineup includes the WiiM Mini, Pro, Pro Plus, Amp and Ultra being their flagship device, which enable high-resolution multi-room audio streaming from services like Spotify, Tidal, and Amazon Music while supporting modern protocols like AirPlay 2, Chromecast, and Roon Ready.
This integration will give you both Media Player for currently playing music as well as full remote entity.
Features:
Media Player Control
Full Playback Control: Play, pause, stop, next, previous, seek
Volume Management: Volume up/down, mute/unmute with real-time feedback
Advanced Controls: Repeat modes, shuffle, source switching
Live Metadata: Track title, artist, album, artwork display
Progress Tracking: Real-time position and duration updates
Source Management
Multi-Input Support: WiFi, Bluetooth, Line-in, Optical, HDMI, Phono, USB
Service Integration: Spotify Connect, TIDAL Connect, AirPlay, DLNA
Smart Discovery: Automatic detection of available sources per device
Remote Control Interface
4-Page Layout: Organized transport, sources, presets, and EQ controls
Dynamic UI: Pages adapt based on device capabilities
Preset Support: Up to 12 user-configured presets with service detection
EQ Management: Full equalizer control with 22+ preset options
Please read the README.md File carefully. For best results, use static IP to your WiiM player.
I have built this and tested against the WiiM ultra, however integration should function with all the other models as the remote get built based on what is available for your WiiM device.
@harvey28 just for you, lol. :joy:
That’s very kind.
But I don’t own a WiiM!
Time to buy a WiiM :rofl:
I have an Arylic which seems to have the same API. My problem I ran out of slots for uploadable integrations :frowning:
What’s the integration limit?
I think 10. I have 10 uploaded and now I get an error that limit might be reached.
Are you with remote 2 or 3?
Only for the ones you upload. The integrated ones like Sonos, Hue, Apple do not count.
I created a feature request. Perhaps you also comment this request so that I am not alone :grinning_face_with_smiling_eyes:
Done. Commented.
I’m at 10 now with all my integrations.
I should’ve purchased 2 remotes lol. One for Dev one for prod. Lol
I have 3 :partying_face:
I’m envy! Lol
Commented. Thanks for posting this bug.
It is no bug it is feature request.
Depends on your point of view!
I do not think so. A bug is something which is NOT working at all.
Up to 10 it is working. Same was with Android TV, Denon, BlueTooth they started with only 1 device and now a lot more.
Give them time.
I’m in no rush as I’ve only got 6 custom integrations installed.
Mind you, the rate at which M.a.S.e is progressing might fill up the rest pretty quickly!
Maybe not a bug, but yet another design fault.
But anyway, thanks again for bringing it to their attention.
lol. i am working on my next one, but dont worry, i am definitely running out of idas lol
New update is up:
  1. Add docker image
  2. Add physical button mapping
  3. Add ok/select button
  4. Add buttons avaialble during activity page creation
  5. Add input_source to media player with app pre-configured music sources
  6. Update README.md instructions
  7. Misc bug fixes
    GitHub - mase1981/uc-intg-wiim: Full Support for WiiM products with Unfolded Circle 2/3 Remotes
New update. Fix reboot survival
New version 2.0.0, complete rewrite with new media browser support, new reconnect logic, new reboot survival logic, new sensors, new select entities. Thank you and hope you enjoy this release.
