Which IR-Codes are supported?
Hi, there,
on many screenshots from the Web-UI you can see, when users are obtaining IR-Codes to a button, that they choose Pronto Hex Code from the selection field. But which Codes are also selectable? NEC?NEC32? RC5? RC6? Lirc?
Who knows?
In the Web Configurator you can choose between Pronto and Hex. There are more infos about the internal supported formats in the library used by the Dock: IRremoteESP8266/SupportedProtocols.md at ucd2 · unfoldedcircle/IRremoteESP8266 · GitHub
Many thanks for your fast response!
