Where to find ChangeLog?
I am using Unfolded Circle Remote 3 with software version 2.8.4 . Now I wonder if updating to version 2.11.0 - shown right now as latest available version.
I wonder where to find the change-log. UCs website is not presenting reliable data.
Can I get back to older versions? How?
Web site is only 1 update late
For current versions you must check the beta box.
All updates have change log on discord.
Ok, thanks. I just wonder, why they do not link officially to it.
How ca
N I downgrade the RC, if a firmware will cause issues?
You can downgrade to the latest non-beta firmware with a factory reset and doing a firmware update afterwards.
