It has been a very long time my remote has had an update.
I have read there have been beta updates, but not sure if I should switch to beta software.
In the meanwhile is everything on the roadmap keeps pushing back!
When will they be implemented?!?!
One of the reasons I bought this remote was because of the OpenHAB integration.
It was first on the roadmap for end 2023, then skiped to 2024 and now for somewhere in 2025!
I’m really dissapointed with this.
the remote not cheap the possibilities are huge I think and at the time the best alternative for my Harmony.
I hope someone can tell more about should I use the beta and what do I get?
Is OpenHAB available in the beta?
And is there more information when we really can expect new stuff and updates?
I would definitely go for the current beta. The released version is quite old, and several new features have been added in the meantime. Actually, there might be another released version sometime soon. I assume that will be the case with the release of Remote 3 at the latest.
+1 from me for update all default integrations were update since 1.7.4 and Bluetooth integration was new. Also new is that you can upload external integrations to the remote now and there are already quite a bit of integrations to be uploaded. Here is a list:
If you want the beta update you must enable beta updates in settings, software update. If you want Bluetooth you must enable this in Preview Features.
Not to forget the new configurator which is in the beta integrated which will be the next standard configurator so that you can get used to it.
