Hi all, sorry for this newbie question, but I’ve noticed that in entities I’ve created, I’ve seen an extra command called IR command or IR sequence that I didn’t teach IR codes too. What do these mean? They are seen in Activities, Sequences when I’m trying to add a power on or off sequence. Does this have something to do with IR powering on when I don’t have a decreet ON or OFF code and the Power is just a toggle ON/OFF single command? I can’t seem to get those to work.
Normally if you send for instance DIGIT_1 this command is send.
With IR command you can also send DIGIT_1 but with additional parameters delay, repeat and hold.
With IR sequence you can send several commands in a row with a delay in between like DIGIT_1, DIGIT_2 with the same additional parameter from IR command. This is perfect for PIN numbers or IPTV channel numbers.
Oh that makes perfect sense. Thanks.
(Was this explained somewhere that I have missed?)
I do not know. I got it from reading discord the best source of information for R2/R3.
