I cannot get “entities”, “activities & macros” or “settings” to open when I click on them in the web configurator. I’m running the most up to date software/firmware on my Remote 3 and my docks. Also cannot get my Remote 3 to pair with my Nvidia Shield using the Bluetooth option when I go to “add a new device.” What’s the deal? I thought the Remote 3 was going to be a step up from my Remote 2, but it’s just the same frustrating nightmare so far.
Kevin T
Factory reset did jack shit all nothing except change the pin code to get into web configurator. Tried it on Microsoft Edge & all the options work. Are you fucking shitting me? Doesn’t work for shit on Chrome, but works fine on Edge?! Shit, maybe I need to download Netscape Navigator to get the full experience.
Kevin T
It works for me perfectly in chrome. I only use chrome for my R2/R3. Did you reload page or clear cache?
I’ll give it a try when I get in from work this evening. Also gonna try to teach the R3 some IR commands and setup Nvidia Shield via BT so be ready for another frustrated diabtribe.
Kevin T
