Web Configurator change not updating on remote 2
I connect to configurator, add remotes, they never update onto the remote. What am i doing wrong?
Did you restart the remote? Maybe this will help
On first page of configurator you see an image of the remote were you can change what is visible at the remote. If you click on the maximize icon you can add groups and entities. A remote is an entity.
With groups you can sort devices or activities.
fyi everything you see in the configurator is already on the remote as the remote is the server for the configurator.
This is a quick suggestion, not trying to be a wise guy. Do you have the remote in the dock or someway that iyt is awake when you make changes so webconfigurator is connected.?
