Manufacturer: Vu+
Model: Uno4kSE & Ultimo 4k
Hi, I´m trying to add more IR devices to control with the remote.
I can´t find the Codes for VU+ receivers.
How can I add my receivers?
Thanks.
Manufacturer: Vu+
Thanks.
You can find them on Globalcache.
How to use: Link
I posted mine (for Duo2, should be nearly the same) here
all VUs except the early Solo and Duo are using the same 4 code sets. Default is 2 but can be changed.
Does this board a possibility to upload codes?
Hi, I can´t reach the links to dicord. Is an invitation required for this?
I think you need an account for discord.
Beside VU+ discord is for UC/R2 very good because the community over there is very active. Much more then here.
Is it possible to renew the invitation?
Just use unfolded.chat
