Volume doesn’t work with Sony Bravia TV
Volume doesn’t work for remote 3 with Sony Bravia TV. I tried looking for the HDMICEC input, but didn’t notice anything in particular. The slider bar also doesn’t seem to work.
Do you use IR or IP (Android TV)? The slide bar must be configured but only some devices can be configered for volume as it needs a special command for that.
The slider isn’t working for me; is there a way to activate it? If so, how?
You must have either a media player widget or device with a special volume command in you activity. Only volume up/down is not enough.
