Hi all, I am so impressed with the new Remote Two and am loving it! So far I have configured the following integrations and they work great (as a start!):
- Roon
- Home Assistant
- Sonos
I have also created a profile and a Living Room page to include the following entities:
- Samsung TV - model UE70RU7092UXXH (using the core Generic Samsung Remote from UC)
- Music (Roon integration)
- Light (from HA)
- Nest thermostat (from HA)
The TV remote works well, all buttons work as expected, except the volume buttons. The Samsung TV is connected to Sonos Playbar via optical. Using the default Samsung remote I can change the volume but the volume buttons on Remote Two do not work.
To try to resolve this I have created an activity using the Samsung Remote entity, Sonos entity and map the volume up/down/mute to Sonos entity but it is not working. I also tried learning the IR code from the original Samsung remote but it still does not work. In between changes i have also rebooted the remote to make sure the configurations are loaded accordingly. Too bad I still can’t figure out how to use the Sonos volume control on Remote Two.
In the IR remote configuration page I cannot map the buttons other than the ones from the remote itself. So I have no idea how to resolve this issue? I am so close to finishing up my first page and hopefully someone here can help me out!
Thanks in advance!
