Vero V Media Player
Has anyone setup an R3 with this Kodi media player?
If it is a real Kodi the Kodi integration should work. Did you already tested it?
I have a remote 2 working well with the Vero V and the Vero 4K+. You can use the Kodi integration found here: GitHub - albaintor/integration-kodi: Kodi integration for Unfolded Circle Remote Two
Thanks @HarmonyFan and @uvjim for your responses. I have ordered the Vero but not yet received, so this gives me a head start knowing there is a generic Kodi integration. I assume if it works with R2 it works with R3. Thanks!!
