Using Home Assistant -?
how do I update added integration items made in home assistant into my remote?
Integrations → Home Assistant → click + on the right of Configured entities
For me new HA entities appear there immediately after they are added on HA
If you’re using the HACs integration for Home Assistant, then entities from HA aren’t automatically added to the remote. It changes the way entities are exposed, so you have a bit more control.
If you want to add entities, in HA go to Settings → Devices & Services → Unfolded Circle
There are more instructions at the repository
