Upgrading existing integrations like the LG TV integration
Will these integrations ultimately work in a similar way to home assistant when upgrading i.e. the upgrade can just be applied over the top of the existing integration rather than having to delete the existing integration and start again from scratch each time?
You have to delete twice, upload new version and start setup. It does not effect your activities.
If you have an Apple device you can also use the unofficial App that supports integration updates, although you still have to re-run the setup afterwars. However the LG integration has a backup/restore function to quickly finish the setup. ‎U Remote Control on the App Store
At some point the firmware will also support updating integrations and including them in backups. I assume when the Wifi problems with the R3 are solved.
