Update tikking sound
I discoverd that when i removed the ethernet cable the sound is gone and when i reset the remote to factory settings when i settup the device i Didn’t found the dock
When i changed the ethernet cable from the switch to the providers modem the sound is gone ??
Try to use a different power supply
thanks Kenny but my last action did the trick
