Update question
Hi ALL,
The last couple of updates to my R2 seemed to go differently from before although they did update and the remote seems to be working properly.
For those latest updates I tapped on Download and the update downloaded (this is still sorely in need of a progress bar!). Then I tapped on Install and watched the progress bar for the 2 stages of the update. Then it says it will reboot and it starts that and the screen goes blank. In the past after a minute or so the remote would restart all by itself. But for these last 2 updates after the remote started the reboot and the screen went blank nothing would happen for many minutes. Ultimately I long pressed the Power button and the remote started and everything worked ok.
Has there been a change in the update procedure in that you need to manually restart the remote after the update process?
Thanks,
Gerry
