Unstable FireTV connection
I’m really happy with the new Remote 3. The only thing that annoys me now is, that the remote looses BT connection to FireTV after a while, when not using it (power saving problem?). No ATV command possible. After powering off and on the relevant activity via the remote, everything works as expected again. Any ideas?
Prevent sleep for activity set? If not the remote goes to sleep and after pick up it takes a few seconds before she can used again.
Preventing sleep sounds like a good workaround. Thanks for the hint! And yes, normally everything is fine a few seconds after wake up, but unfortunately not for FireTV…
Bluetooth is disconnected after command is send and connected when a new command should be send. A least that was the case when I tested it with my Fire TV sticks.
Preventing sleep did the trick. Thanks for that.
