Tobbes
1
Is it possible to turn the PS5 on and off?
The only way I know to do that is using Home Assistant. It works, but requires additional hardware.
Tobbes
3
I use HomeAssistant. Can you explain how it works?
You have to install an add-on and connect it to your account and PS5.
If you don’t already have an MQTT broker, you will need to install one of those too. I used Mosquitto.
