Turn off Apple TV Instant using IR
Hi All,
I guess most Apple TV users are not amused by apple making you click the home button and then click again enter to turn off their device well after some digging I found a PRONTO code:
229_021_DISCRETE_POWER_OFF (Immediate)
0000 006C 0022 0002 015B 00AD 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0575 015B 0057 0016 0E6C
Enjoy! PS: Don’t forget to change the output to default otherwise nothing will happen :wink:
Or use the Apple TV integration.
Interesting. I am using the Apple TV integration which does not have that problem and did not even know that the Apple TV can be controlled via IR.
yeah for me it some how just opens the control center in the top right corner and then asks me to click okay if use the integration for power off but the IR does the job for me.
yeah all apple tv 4k versions have a IR receiver
