I am having issues detecting my Sonos speakers. They are all on the same VLAN as my remote but when I try to install the integration it says no detected speakers. I have S2 devices. Does anyone have any ideas?
Thank you
Thank you
The firmware release notes mentioned something about the current Sonos integration issues and the need to reprogram the whole thing. A workaround seems to be rebooting the Sonos devices.
