Manufacturer: Trinnov Audio
Model:Altitude 16
Is one of you using IR datast for Trinnov, every button gives me a “bad request” error, what can I do?
thanks
Model:Altitude 16
thanks
Can you post debug logs of the core and dock?
Thanks "kennymc.c,
Thanks for your help,
But I don’t know where I can find the dock logs?
Could you tell me how to proceed?
After the error message appears go to the web configurator/Settings/scroll down to Development and click on Logs. In the first dropdown menu choose Core services and user interface app, in the second dropdown menu choose the last entry DEBUG. If the dropdown menus are all empty try to reload the page. This is a known bug.
I’ve got the same error w/ Philips IR Dataset ![]()
Enclosed is my error log.
| 2024-03-24 20:03:39.505456 +00:00 | core | ERROR | [Watch TV] error executing activity command uc.main.c8d489dc-e573-466f-b2bb-3277e61824eb:remote.on (ignore error: false): BadRequest: Bad request |
| 2024-03-24 20:03:06.826302 +00:00 | core | ERROR | [Watch TV] error executing activity command uc.main.c8d489dc-e573-466f-b2bb-3277e61824eb:remote.off (ignore error: false): BadRequest: Bad request |
| 2024-03-24 20:03:01.600627 +00:00 | core | ERROR | [Watch TV] error executing activity command uc.main.c8d489dc-e573-466f-b2bb-3277e61824eb:remote.off (ignore error: false): BadRequest: Bad request |
| 2024-03-24 20:02:48.972999 +00:00 | core | ERROR | [Watch TV] error executing activity command uc.main.c8d489dc-e573-466f-b2bb-3277e61824eb:remote.off (ignore error: false): BadRequest: Bad request |
| 2024-03-24 20:02:01.889347 +00:00 | core | ERROR | [Watch TV] error executing activity command uc.main.c8d489dc-e573-466f-b2bb-3277e61824eb:remote.on (ignore error: false): BadRequest: Bad request |
| 2024-03-24 20:01:45.332855 +00:00 | core | ERROR | [Watch TV] error executing activity command uc.main.c8d489dc-e573-466f-b2bb-3277e61824eb:remote.on (ignore error: false): BadRequest: Bad request |
| 2024-03-24 20:01:31.315118 +00:00 | core | ERROR | [Watch TV] error executing activity command uc.main.c8d489dc-e573-466f-b2bb-3277e61824eb:remote.on (ignore error: false): BadRequest: Bad request |
Debug (for all services) does not hold anything than Philips Hue related entries(?). Maybe I am doing something wrong when creating the log though.
Many thanks, Philipp
Dear kennymc.c
below the logs, I don’t fully understand the logs, but I already see an error,connecting to dock
thanks again for your feedback
| Column 2 | Column 3 | Column 4 |
| core | NOTICE | No dock updates available |
| core | NOTICE | Contacting OTA server for dock update check. Channel=default, version=0.10.0 |
| core | NOTICE | Check OTA server for dock firmware update: UC-Dock-8C4B14AA776C |
| core | NOTICE | No session state has been found for a valid session key, creating a new empty session. |
| core | NOTICE | Changed battery status: 89% Charging, 4180mV, charger: true |
| core | NOTICE | Setting button backlight to: 0% |
| ui | INFO | uc.ui.input: TAKE CONTROL FROM MainContainer_QMLTYPE_187(0x5586bfc840) → QQuickContentItem(0x5586c0d410, \QQuickPopupItem) |
| ui | INFO | qml: Button control enabled for: QQuickContentItem(0x5586c0d410, QQuickPopupItem) |
| core | NOTICE | Changed battery status: 88% Charging, 4159mV, charger: true |
| ui | INFO | uc.ui.input: TAKE CONTROL FROM Remote_QMLTYPE_210(0x5587434550) → MainContainer_QMLTYPE_187(0x5586bfc840) |
| ui | INFO | uc.ui.input: Key released: HOME MainContainer_QMLTYPE_187(0x5586bfc840) |
| ui | INFO | qml: Button control enabled for: MainContainer_QMLTYPE_187(0x5586bfc840) |
| ui | INFO | uc.ui.input: Key pressed: HOME Remote_QMLTYPE_210(0x5587434550) |
| core | NOTICE | Changed battery status: 88% Discharging, 3996mV, charger: true |
| ui | WARN | uc.ui.entity.controller: Cannot execute command: remote.send 400 Bad request |
| core | NOTICE | IR toggle state of IR command uc.main.ba241d55-9f14-4cc9-8e39-c3d92687908b SOURCE_NEXT: false |
| core | NOTICE | IR toggle state of IR command uc.main.ba241d55-9f14-4cc9-8e39-c3d92687908b FORMAT_NEXT: false |
| core | NOTICE | IR toggle state of IR command uc.main.ba241d55-9f14-4cc9-8e39-c3d92687908b INPUT_HDMI_2: false |
| core | NOTICE | IR toggle state of IR command uc.main.ba241d55-9f14-4cc9-8e39-c3d92687908b INFO: false |
| core | NOTICE | [UC-Dock-8C4B14AA776C] SessionAuthenticated msg |
| core | NOTICE | [UC-Dock-8C4B14AA776C] Session state change: Authenticated |
| ui | WARN | uc.ui.entity.controller: Cannot execute command: remote.send 503 Connection to dock not established |
| core | ERROR | Error sending dock command ir_send: Connection to dock not established |
| core | NOTICE | IR toggle state of IR command uc.main.ba241d55-9f14-4cc9-8e39-c3d92687908b MENU: false |
| core | NOTICE | IR toggle state of IR command uc.main.ba241d55-9f14-4cc9-8e39-c3d92687908b INPUT_HDMI_1: false |
| core | NOTICE | [UC-Dock-8C4B14AA776C] Connected to: ws://192.168.10.68:946/ |
| ui | INFO | uc.ui.input: TAKE CONTROL FROM MainContainer_QMLTYPE_187(0x5586bfc840) → Remote_QMLTYPE_210(0x5587434550) |
| ui | INFO | qml: Button control enabled for: Remote_QMLTYPE_210(0x5587434550) |
| core | NOTICE | [UC-Dock-8C4B14AA776C] Reconnecting in: 844ms |
| core | ERROR | [UC-Dock-8C4B14AA776C] Error connecting to dock ws://192.168.10.68:946/: TimedOut |
| ui | INFO | uc.ui.input: TAKE CONTROL FROM Button_QMLTYPE_209(0x558735ab00) → MainContainer_QMLTYPE_187(0x5586bfc840) |
| core | NOTICE | [UC-Dock-8C4B14AA776C] Reconnecting in: 650ms |
| ui | INFO | uc.ui.input: TAKE CONTROL FROM MainContainer_QMLTYPE_187(0x5586bfc840) → Button_QMLTYPE_209(0x558735ab00) |
| ui | INFO | qml: Button control enabled for: Button_QMLTYPE_209(0x558735ab00) |
| core | NOTICE | [UC-Dock-8C4B14AA776C] Reconnecting in: 500ms |
| core | NOTICE | [UC-Dock-8C4B14AA776C] on_session_disconnected: ClientDisconnect |
| core | NOTICE | [UC-Dock-8C4B14AA776C] Session state change: Disconnected |
| core | ERROR | [UC-Dock-8C4B14AA776C] Websocket server heartbeat failed, disconnecting! |
| core | NOTICE | Changed battery status: 88% Discharging, 4091mV, charger: false |
| core | NOTICE | Setting button backlight to: 54% |
| core | NOTICE | [UC-Dock-8C4B14AA776C] Force stopping actor |
| core | WARN | [UC-Dock-8C4B14AA776C] Can’t handle dock ConnectCmd command in state: Active |
| core | WARN | [UC-Dock-8C4B14AA776C] No transition for: state=Active, event=ConnectCmd |
| core | WARN | [UC-Dock-8C4B14AA776C] Old connection is still open, closing it |
| core | NOTICE | [UC-Dock-8C4B14AA776C] WiFi connected: connecting dock |
| core | NOTICE | WiFi interface is up and routable, sending connected event |
| core | NOTICE | Network changed: link_name: wlan0, operational_state: routable, address_state: routable, ipv4_address_state: routable |
| core | NOTICE | Ignoring connected event from WiFi driver, using operational state instead |
| core | NOTICE | Network changed: link_name: wlan0, operational_state: degraded, carrier_state: carrier, online_state: online |
| core | NOTICE | Network changed: link_name: wlan0, operational_state: dormant, carrier_state: dormant, online_state: offline |
I tried to connect the Dock via RJ45, did a factory reset, but still the same problem, does anyone have any suggestions?
thanks
If you haven’t already done this, try to change the url of the dock in the dock settings to the ip address of the device instead of the .local domain.
@ kennymc.c,
Thanks for the answer, unfortunately I had already tried, but without success, would you have another suggestion?
Dear All,
I don’t know what the problem was, but it was solved by manually adding the IR code from the original trinnov remote control.
Thank you all for your help
