Tips / Suggestions / My Experience so far
I’ve owned the remote 2 + dock for well over a year at this point, and when I first got it, I wasn’t able to get things into a stable enough state that I’d consider unleashing it on my family. But a year later, some debugging, some help from the forums, and I think things are in a much better state, but there are also some things that are, IMHO, kinda hidden away.
So I wanted to share some tips and advice, and generally share my experience.
My devices:
  • Denon AVR
  • LG TV
  • Playstation
  • Roon streamer
  • Apple TV
  • Home Assistant
These devices are all connected via the AVR, and in a single room, aside from HA.
The challenges I’ve hit so far are:
  1. Debugging is (IMHO) MUCH easier if you have live logs - web app log viewer. This was a critical step for me (and thanks to this forum and it’s helpful folks in pointing it out).
  2. Activity Groups have some settings, if you are having problems, the doco here is useful: activity groups. The gotcha for me was, the Roon Integration does not support on/off. This makes the default activity group setting of “always” turn off unused entities fail. “In Off Sequence” fixed this.
  3. External Integrations require the beta firmware, which requires a reboot to enable. Flipping “use beta firmware” and then clicking “check for newer version” doesn’t work.
  4. If you are messing around adding / removing integrations (which I found necessary, perhaps due to many updates over the year since I last played with the remote), can mess up your activities. The best solution to this is the UC Remote Two Toolkit - it’s ugly as sin, but very powerful functionality, including the ability to swap entities. I wish I’d found this earlier (and again, thanks to the folks in this forum!). The UC Remote Two Toolkit also allows running activities from the web interface, which I found very useful for debugging.
I doubt I’m “done” here, but the above was enough to get me to a state that I think is workable, and my testing doesn’t show any problems.
Thank you to everyone in this forum, it’s made a world of difference. And given the forum is mostly people discussing problems, I thought I’d share something more positive. Hopefully this is helpful to someone!
I would add:
  1. Use backups every time you make changes so you don´t have to worry to mess up your configuration.
  2. Take a look at the discord channel it is a lot more active than this board.
With a few minor limitations I am already at a 98% perfect remote :rofl:
