Tap here to open settings
I can’t get into the settings and therefore probably can’t get a new PIN for my Configurator.
it worked before, what can i do? someone a tip
Please enter PIN to get started
Where do I get this pin code from?
If you see “Tap here to open settings” your are on the initial help screen. Press the Close button on the bottom of the screen to dismiss that message.
After that you’ll be able to tap the profile icon in the top right corner.
yes that works thank you I’m back in
