This weekend I played a bit with favorites for TV/Radio. I created macros for channel 11, 12 and so on but I could not assign a macro to the icon on the display.
The easier way to achieve what you are trying to do is use IR sequences:
I already tested with adding Macro as entity to an activity and it worked. I will try your way perhaps it is working with devices not activities.
