Spotify Recently Playing Media and Controls
new version up, updated.
new version is up with support for multi account, discovery and much more.
Hi @M.a.S.e thanks for all the awesome work on this! I downloaded the GitHub package but just wanted to confirm if it’s possible to browse the Spotify library/albums and play from the remote? Every time I try to open the player on the remote I get an error but not sure if library browsing is working now or coming later?
Yes you should be able to browse your library and play directly from the media player widget assuming you have added this to your remote UI in the activity.
Thanks for the reply and tip. Every time I click on a source I get a “Error sending the command - Spotify player is not responding” message. I can pause, play and change volume fine, but I can’t seem to change sources or I don’t see how to access the browser - probably because the command isn’t getting through.
When I setup the integration in the web config I can add the following entities:
-spotify player
-spotify remote
-spotify active device
-spotify now playing
is the media browser part of the player entity?
I am using the Spotify integration by MeirMiyara (v3.5.4) on a Remote3, and it works as expected.
Now, I would like to set it up on my second Remote3 as well.
Do I need to create a new, separate Spotify app for this, or can I use the existing Client ID and Client Secret from the first Remote3?
Existing is fine.
It works!
thanks!
