Sony STR-AZ3000ES Integration
Hi I received my Unfolded 3 Remote and I am trying to setup my Sony AVR. I downloaded an integration from Github from Albaintor and I keep getting Connection_Refused. Can anyone help or is there another way that I can get my AVR up and running? Thanks
I don’t have one of these however have you tried enabling External Control as described here?: STR-AZ7000ES/STR-AZ5000ES/STR-AZ3000ES | Help Guide | Turning on control mode for maintenance (External Control)
Hi thanks for the suggestion. I will try this and see if that works.
YES! It worked. Thank you. Now on to the next learning.
