Hi. I’m new to the Remote 3 and I’m long time Harmony user. I’m trying to setup my living room devices: LG TV, Zidoo Z9X, Optoma projector and Sony STR DN1080. I have managed to setup all the devices so far through integration or through IR learning. But I can not create any activity because I can’t configure Sony receiver and it is the most important because all the devices are connected to it. I have installed Sony AVR integration by Albaintor and it recognized receiver after manual IP setup. Made an activity and set up ON sequence but the receiver commands don’t work. It gives error message on remote. I have made IR entity for the receiver but not all commands are on remote (eg. Input Video 1 and 2, and Output zones A and B) and I need them all.
Which error during start sequence? I guess that the on command could not be send. Some AVR disable WiFi if switched off. Take a look in the settings of your Sony.
You were right. Thanks! I switched on the standby for the power off and it’s working now. The only thing that is left now is the problem with outputs (Zones A and B). Remote has one button that cycles the outputs between A,B and A+B. But in Harmony there was separate command for each output. So is in Sony AVR integration but it is not working for some reason.
Does anyone know why the Zone output commands are not working in this integration? There are separate commands for Zone A, Zone B, Zone A+B and Zone Off but none of them are working on my Sony AVR. And sadly it would be a dealbreaker for me since my Home theater is set up so that I’m using Zone A for TV and Zone B for projector.
