Sony (Android) TV integration
I am running a simple activity with three integrations: a sony android tv (XR-65A95K), a denon AVR-3800H, and an appletv 4K. It works fine, except that after powering off, the next day, when attempting to start the activity, the sony tv is not active/connected and the activity fails. Once I turn the tv on with the original sony remote, everything works fine. Activity starts up. Activity stops and powers down. It’s only after 24 hours or so or overnight that this occurs. Can anyone help?
This probably due to an energy saving parameter on your tv that will completely turn off the tv after a while. You should be able to disable it I guess.
Otherwise you can add a turn on command with IR on the startup sequence
My Philips behaves similar. I found out that it starts if I send a power signal with IR but then it takes a lot more time to boot because AndroidTV must be loaded/initialized. The time is to long for the timeout of the R2.
