The Sonos integration doesn’t seem to work for the older generation S1 systems ( or at least I am not getting it to work).
Is this correct assumption?
my Play:1 is also not found. It is only connect with a network cable. No WiFi and the old communication between the old Sonos which are using their own WiFi protocoll.
I did not use my Play:1 for some time. I made a firmware update lst week and after that I could create Sonos entities but when I tested a Sonos Activity nothing worked:-(
