Sonos Integration
Hello,
I’m the proud owner of the remonte 2, and I’m trying to keep it under control. I have a sonos system but it doesn’t appear in the integrations. In the integrations I have B&O integration but I don’t have a B&O device.
Is this a bug or something I’ve got wrong?
From what I’ve read, the Sonos integration is still under development.
Thank you for the info I will wait for update
What happened with this? Are you now happy? I have Sonos as well…
In principle, the Sonos plugin works. The devices are found and you can control them. Covers are also displayed. What I don’t think is possible yet is things like playing favorites or playlists or navigating/searching for tracks. Operating devices that are sometimes grouped and sometimes not grouped will also be problematic.
But there is a general problem with Sonos at the moment. I would wait until everything is running smoothly again before wondering why something isn’t working with the plugin.
Sure - no worries. I now use my Sonos players as just dumb Spotify Connect or HA Music Assistant endpoints anyway. Ive pretty much left the Sonos app/ecosystem. Hey is everyone aware Music Assistant has be brought into HA as an official supported integration? Be really cool if control of that appears on the remote screen?! What about Spotify?> I guess there is pretty good direct control of Spotify playlists etc?
